Old 07-29-2012, 11:09 AM   #1
Life expectancy of residential central air
I purchased and installed a central air unit for our home back in the Spring of 1998. This American-Standard unit, which appears to have a SEER-10 rating, has never given us any trouble and has never needed to be serviced.
I realized yesterday that next Spring will be 15 years since installation! Obviously a simple service inspection is well past due, but with its age is it even worth the cost? Or should I instead be considering replacing it with a current baseline efficiency model next year?
With the exception of this summer the A/C usually will not operate enough here in Michigan to justify the increased cost (and increased complexity) of the highest efficiency models.
MI-Roger is offline   Reply With Quote
Old 07-29-2012, 03:12 PM   #2
it should not cost that much to preform the summer maintenance on the unit. The average life expenctance is around 15 year for a A/C, but that does not mean yours won't last 20 or more. the oldest running residential A/C unit I ever worked on was around 35 years old. I currently see many units still running that are 20 + years old.
If you have a medical condition or want to limit the possiblity of living with out A/C for a few days and can aford it replacing it would not be foolish.
turnermech is offline   Reply With Quote
Old 07-29-2012, 03:51 PM   #3
Never been serviced? Not even maintenance? Find a local contractor who your friends or neighbors know is good and have them do a check up. It is cheap insurance if you can find a good mechanic to have it looked at once a year.
FrankL is offline   Reply With Quote
Old 07-29-2012, 05:23 PM   #4
Yeah, I am a little embarrassed by this. The furnace gets a new MERV-11 filter every three months. The outdoor compressor/condensor unit gets wrapped with a single layer of fiberglass window screen from mid-May to mid-July each year to keep cottonwood fuzzies off the condensor fins, but otherwise no maintenance. The A/C system continues to just run like a top since the day it was new.
Old 07-29-2012, 09:03 PM   #5
Amazing. Sounds like the filter changes and wrapping have protected it well. Some of the older stuff can last a long time if it is not pushed too hard.
Old 07-29-2012, 09:15 PM   #6
well Iam from the old school...its never been serviced its 15 yrs old...its not broke don't fix it....run it till it dies...just my thougth..ben
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Evstarr (07-30-2012), Hardway (08-02-2012)
Old 07-30-2012, 12:14 AM   #7
I'm afraid that I'm just cynical enough to believe that if you bring someone in to look at it now and especially if you tell them it's never been serviced, that they'll muck about with it just to prove a point and you'll start having issues. If the ports haven't been operated in all those years, just connecting gauges could leave one jammed open or dislodge some gunk into the lines and now you have a repair.
Just my 2€. I'd leave well enough alone at this point.
Evstarr is offline   Reply With Quote
The Following 2 Users Say Thank You to Evstarr For This Useful Post:
ben's plumbing (07-30-2012), homecomfort (07-30-2012)
Old 07-30-2012, 09:26 AM   #8
Someone else says, and I agree, old school, don't fix what ain't broke.
I have a hard time believing you don't do any other maintenance? Do you ever clean the thing? No dust, no mud? Do you cover the compressor over the winter?
homecomfort is offline   Reply With Quote
Old 07-30-2012, 09:35 AM   #9
Well ... this is not a matter of being "broke", it's a matter of trying to keep it from being broke.
You wouldn't say the same thing about changing the oil in your car, I would assume. There's no difference in providing maintenance to your A/C system. As others have said, find a good contractor in your area - ask friends and neighbors, and check BBB ratings and such.
Given some of the incompetent crooks in our industry, I can certainly understand your point. However, in most cases those guys don't stay around too long, and tend to prey on the bottom dwelling consumer (the "I want the cheapest price no matter what" mindset). Homeowners who do their research, get recommendations from trusted family and friends, and don't shop around based solely on price tend to have very good relationships with their contractors.
scottmcd9999 is offline   Reply With Quote
Old 07-30-2012, 10:29 AM   #10
Missouri Bound's Avatar
Let me add to the "old school" phrases. When troubleshooting, "turn it on and see what smokes"
Do you want it your way or the right way?
Old 07-30-2012, 11:17 AM   #11
I agree with you scott under normal reasons....this is not normal....it been 15 yrs no service...its about getting to the time to replace it.....when it breakes replace it ..no questions....ben sr
Old 07-30-2012, 12:43 PM   #12
I disagree with the when it breaks replace it.
read up on how basic systems work and you will be able to handle just about every failure, except a leak. Leaks are for the pros. EPA says so.
The rest is no more complex then a car and in fact far simpler. All you need is a working knowledge of your system to keep it running for another 15 years.
bobinphx is offline   Reply With Quote
The Following User Says Thank You to bobinphx For This Useful Post:
Old 07-30-2012, 01:48 PM   #13
I"m 50 /50 on this. It's true you can replace 90% of the parts and keep it running, but a 15 year old unit will be more costly to operate and work less efficiently as a new unit. It's one of those spend it now or spend it later issues.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 08-02-2012, 06:51 PM   #14
I am seeing a lot of analogies to auto maintenance. My car came with a book of regularly scheduled procedures. Why didn't I get a book? What regular procedures should be done with a conventional cooling system to keep it running for as long as possible?
ionized is offline   Reply With Quote
Old 08-02-2012, 09:53 PM   #15
Most AC last more than 20 years in that part of the country. It only get used 2 months of the year the most, and only a few hours (some days only 1 hour) a day. Filter only needs to change once every year, or two years. (not hot air heat, so no filter for heating). I lived in northern MI between 1980-1990, My AC never serviced either, I only changed my filter once every 2 years. Never had problem.
clocert is offline   Reply With Quote
Life Expectancy of Home Components sdsester How To Guides 4 06-01-2012 02:10 PM
Life expectancy of coil r a raper HVAC 2 01-02-2012 08:35 PM
cellulose insulation life expectancy jjmch Roofing/Siding 3 04-11-2010 11:40 PM
Rheem power vent blower motor life expectancy? windowguy Plumbing 4 09-04-2009 12:39 PM
Shake Roofing Life Expectancy daveblah Roofing/Siding 3 08-04-2009 06:41 PM
