Lenox Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 08:09 PM   #1
-AC meggase on unit, (running on battery power) heat not turning on. I keep taking the thermostat off the wall and putting it back on, I even pulled out the connection prongs on the back of the thermostst (Lennox Programable) so it would make a better connection with the pins on the wall plate. The furnace will come on for a few minutes then go back to -AC (batteries). Is this a problem with the Thermostat itself? And if so should I try buying a new one and replace it? Last question, should I buy a lennox thermostat or doesn't it matter, are they easy to replace?
Thanks for all your help!!!!
mikerond is offline   Reply With Quote
Old 12-09-2010, 08:18 PM   #2
I don't think it is a stat problem. Do you have 24 volts at your furnace c and r and is it a gas furnace. Norm when you see batt you lost 24 volts. Could be a limit switch that may be why you have power for a second.
Hixheat1 is offline   Reply With Quote
Old 12-09-2010, 08:36 PM   #3
You can pull the stat off the wall and jump w and r to see if it works if it does you pro. Have a bad stat or a break in common
Old 12-10-2010, 05:44 AM   #4
Oil Furnace
It is an Electric Oil Fired Burner.
Old 12-10-2010, 06:54 AM   #5
I recommend if you r not certified to work on oil call a pro.
Old 12-10-2010, 05:43 PM   #6
I have certain techs that specialize only in oil. Oil should be serviced yearly. It is not for the diy people.
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 04:16 PM
Thermostat or oil burner problem? freyguys HVAC 5 02-25-2010 01:44 PM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 04:40 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
