Lenox Heat Whisperer - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 04:58 PM   #1
Have a Lenox Heat Whisperer when the burner stops in the furnace the fan continues even though the fan is set on auto & it does not stop running unless the power is shut off.
Lynn Riehle is offline   Reply With Quote
Old 10-14-2012, 05:42 PM   #2
how
Rewards Points: 1,104
First follow the thermostat lines into the furnace and remove the thermostat line connected to the "G" to see if the problem stops. If it does, you have a stat, stat connections or stat circuit problem.
If not you could try tapping the fan relay to see if it releases.
Usually this means that you will need a new blower board.
how is offline   Reply With Quote
Old 10-14-2012, 08:03 PM   #3
Rewards Points: 582
check to see if there are any safety roll out switchs that may have opened i think some models have that feature....ben sr
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
