-   -   Lennox WP18 Humidifier w/ Pro1 IAQ Humidistat (http://www.diychatroom.com/f17/lennox-wp18-humidifier-w-pro1-iaq-humidistat-167497/)
species8472 12-27-2012 11:03 AM
Furnace - Lennox 2 speed G60
Humidifier - Lennox Healthy Climate WS18
Thermostat/Humidistat - PRO1 IAG T955 WH
I just had the humidifier installed, and the installer also put in a manual humidistat. The humidifier will only activate if there is a call for heat.
My goal is to wire the humidifer to my Thermostat/Humidistat such that when there is a call for humidity, it will activate the furnace blower and activate the humidifier.
So I bought a 24 VAC relay and wired the H and C terminals (of the thermostat) to the "coil" side of the relay. The other 2 terminal of the relay got wired to the humidifier.
When I did this, the furnace blower would turn on when there is a call for humidity, however humidifer fan would not activate.
I had a Honeywell Truesteam humidifer and used the same wiring configuation and it worked fine. I am just not sure why this will not work correctly. I can say that the relay I'm using is brand new and I checked the voltage going into the relay and there is 28 volts going into the relay (according to my volt meter).
Any suggestions would be appreciated.
