Lennox Whisper Heat Troubles - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 05:15 PM   #1
Hello, I have a Lennox Whisper Heat Furnace about '94 (BCC2-2 REV B LB-65126A BOARD AND A MODEL SP745 MODULE NR-C-60-30 PART # 100-00831-01) that I'm having trouble with. I followed the Trouble shooting guide but I am not convinced I have solved the puzzle. My transformer is good. My door opens, blower checks out. Last year when I bought this house it operated a bit funky and would take a few attempts of turning the thermostat up and down to call or not call for heat before it would ignite. Now, it won't ignite at all. I tested the voltage to the gas valve and the PV and MV terminals I get a about 27volts. I tried to manually ignite the pilot after cleaning the Flame sensor and ignitor and nothing. I think this lead me to the Gas valve? I tried turning the gas valve on while calling for heat and the pilot line removed and could not smell NG coming out of the valve. Please someone, help.
Thanks,
~Wayne
NoHeatWayne is offline   Reply With Quote
Old 09-23-2012, 06:30 PM   #2
how
Rewards Points: 1,070
Make sure your gas valve does have a gas supply.
If you are getting 24 V to the PV and no gas comes out of the pilot port of the valve, then the valve is faulty.
how is offline   Reply With Quote
Tags
bcc2 , lennox , sp745 , whisper eat
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
lennox heat pump cooling probs greaseking76 HVAC 1 05-28-2011 08:26 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Lennox Whisper Heat burners won't stay lit Gaff519 HVAC 2 12-09-2010 12:32 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
