Lennox Whisper Heat G20 Not Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 09:54 AM   #1
Lennox Whisper Heat G20 not starting
Hi all,
I've tried everthing that I can think of, but my furnance just won't come on! It's a "Whisper Quiet" Model G20 2002E-50 manufactured in 92, about 20 years old.. I've turned off the gas flow, power, and thermostat and turned everything back on (after 5 minutes) with the thermostat cranked to 90 degrees. Still won't come on. I've checked the lower panel and the safety switch is being depressed correctly with the panel installed. I don't seem to hear any motor hum like i hear from the other next to it. Deems dead!
Any thoughts? I have the replaced the Honeywell ignitor S8660 auto ignition system about 6-8 years ago and as far as I know, it's an electric starter, meaning that there isn't a pilot light that runs continuously.
Is there a place I can locate a service manual?
Thanks in advance for any insights!
gold@nucleus.com
postman56 is offline   Reply With Quote
Old 02-26-2012, 10:04 AM   #2
Check to make sure u have voltage to the unit. Did u check to for a bad fuse or tripped breaker at the main?
hvac5646 is offline   Reply With Quote
Old 02-26-2012, 10:17 AM   #3
Thanks for the help, it's much appreciated. I could of popped something yesterday when i was looking at the filter.
Is there a fuse on these anywhere, I couldn't see any on the circuit board in the lower compartment?
I have two g20's side by side,with master power switches above and the little larger one is working fine, so I don't think they'd be on separate breakers at the panel?
Old 02-26-2012, 10:21 AM   #4
if the board is original...no.fuse. newer boards may have one and they would look like automotive fuses.
Old 02-26-2012, 10:23 AM   #5
Yea no fuses on this old board
Old 02-26-2012, 10:40 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 92
check for 24 volts between R and C on the board with the door switch pressed in.if none you may have blown the transformer. cozyparts.com has some manuals on their page.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (02-26-2012)
Old 02-26-2012, 01:49 PM   #7
how
Rewards Points: 1,104
If no sound at all then I'd be checking if the furnace is getting 120V.
If the furnace has 120V then turn down thermostat and jumper R & W thermostat connections on the furnace board to bypass and test the thermostat & it's wire circuit. Furnace door switch needs to be pressed in for this.
The very start of this furnace cycle is the opening of the motorized door. No sound at all would have me check if the circuit that powers the combustion door motor is getting 24V.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 02-26-2012, 05:27 PM   #8
Remove the stat wires from the board first
The Following User Says Thank You to hvac5646 For This Useful Post:
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Lennox Heat Pump XP15 smorgdonkey HVAC 34 08-13-2012 11:04 PM
lennox whisper heat g20 monserrate HVAC 3 10-03-2011 07:02 PM
lennox cbx32 heat strip problems. mkietz HVAC 6 04-02-2011 04:27 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
