Lennox Whisper Heat G20 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 01:05 PM   #1
lennox whisper heat g20
I did a routing start up of the unit, the pilot frame is on and the vent door open and the fan starts up but it fails to ignite the burner and then after a few minutes it shuts down, could be a sensor or that the burners are clogged up?
monserrate is offline   Reply With Quote
Old 10-03-2011, 01:59 PM   #2
Rewards Points: 380
Whisper heat models light the pilot light first then the pilot is proved by the sensor which reports back to the ignition control (grey or blue box on right hand side). A common problem is the spring on the left hand side of the damper that makes a little end switch to allow spark to the pilot. The spring arm breaks and the pilot doesn"t light. Since your pliot is on, probably a dirty sensor (but then you typically hear it trying to spark ignite for a long time) check power going to gas valve or not. Could be ignition module or gas valve at that point.
HVACDave is offline   Reply With Quote
Old 10-03-2011, 04:49 PM   #3
That's one I'm going to advise you have a local tech come out. Heat exchanger cracks are very likely on that model so you'll want to know for sure before sticking any money in it.
Old 10-03-2011, 07:02 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
I agree with marty and those old gas valve/ignition control combos are no longer available i believe.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Lennox Heat Pump shuts down sully2 HVAC 47 08-19-2011 09:56 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
Lennox heat pump m/n 10acb42-11p rkhayes HVAC 3 07-25-2010 08:07 AM
Lennox xp15 heat pump, power outage blip GEAF HVAC 4 04-02-2010 05:10 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
