Lennox Whisper Heat Burners Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 12:32 AM   #1
Lennox Whisper Heat burners won't stay lit
I have a Lennox Whisper Heat forced air gas furnace that is not working properly. I've already cleaned the flame sensor. I believe there may be a problem with the ignition control module. How do I test it with a voltage meter to see if it needs to be replaced or the problem lies elsewhere?
Gaff519 is offline   Reply With Quote
Old 12-09-2010, 03:09 AM   #2
You got a job on your hands.
hvaclover is offline   Reply With Quote
Old 12-09-2010, 11:32 AM   #3
so your burners do lit then go out? if so then take out your flame senor and test it set your meter on ohm it looks like an omega symbol it will say O.L at first put each lead on each end of the flame sensor if it still says O.L then its bad replace it.
hvac kid is offline   Reply With Quote
Lennox furnace - no heat Greenlawnracing HVAC 35 10-27-2011 01:08 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Heat TXV for Lennox Tator1076 HVAC 24 02-06-2010 08:37 PM
