Lennox Verses Other Brands - HVAC - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 07:12 PM   #1
Rewards Points: 77
Lennox verses other brands
Hello.. Been having problems with the HVAC this year. Low on freon and now that its working again, water is leaking into the furnace due to a rusted out evap drain pan. I did bite the bullet and had a couple of quotes to replace the existing gas furnace/ac with a new system. One quote is for a Rheem and the other is for a Lennox. I always thought Lennox was a Caddilac brand but I've seen a trend of comments on the internet that make me think twice. I so much value the opinions on this site that I will pose the question here. Is there any reason I should not choose the Lennox system once I get fed up with trying to fix this clunker that is in here now? Thanks
SS396 is offline   Reply With Quote
Old 06-16-2011, 07:18 PM   #2
Rewards Points: 6,652
As stated in other threads, a system is only as good as the person that installs it. Name does not mean anything if the system is never maintained properly, or installed properly in the beginning.
Old 06-16-2011, 07:20 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,846
Most of the major brands, Lennox, Carrier, Trane have 3-4 different quality levels. Complaints are usually due to a poor install, not setup properly by the installer or budget line units. The Elite and Signature line of Lennox is like the Buick or Cadillac. You get what you pay for. Even a basic unit like a Ducane if setup properly can work very well albeit a bit louder and with a few less bells and whistles. Most problems are from poor installs and improper setup and maintenance later on.
Old 06-16-2011, 08:41 PM   #4
You are correct on the Signature series. We have a Lennox G61MPV, and love it.
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 06:03 PM
Lennox G61 quote, also water heater and ac bw77 HVAC 1 06-16-2011 07:12 PM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 02:35 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
