-   -   Lennox SLP98 pressure switch issues (http://www.diychatroom.com/f17/lennox-slp98-pressure-switch-issues-163808/)
becsnider 11-18-2012 08:27 AM
Hi -
We have a two-year old SLP98 furnace that will not light. I have had HVAC techs out three days in a row (at $160/visit) and still they really don't know what is wrong with our furnace. Each time they come out, they try a bunch of different things (mostly the same things the other guy tried), read the error codes and after a bunch of trial and error, the furnace lights again and we have heat for approximately 12 hours.
After the furnace stops lighting, it keeps trying to calibrate when heat is called for by the thermostat. The inducer comes on and then the pressure switch clicks, then it keeps ramping up, the pressure switch(es) click a few more times, it keeps ramping up and then shuts down, giving error code 228.
All of the venting has been checked and is clear, all of the hoses leading into the pressure switch have been blown out and are clear. All the wiring is intact.
Seems like the furnace just happens to come back on once in a hundred or more tries by the service tech. Once they get it on, they leave and tell us to call again if it goes off. The latest senior service tech said he thought the pressure switch might be bad, so we are waiting for them to order us a new switch. Of course, they can't get one on the weekend.
Anyone else had this problem? The service tech said he thought that he remembered something about the pressure switches for this unit having a problem. Has there been a recall of them?
Thanks for all replies.
Becky Snider
yuri 11-18-2012 08:40 AM
There have been a few failures of those switches but no more than average. The inducer needs to ramp DOWN to its lowest speed to calibrate the high and low aspects of the switch/venting. If it does not ramp down then it usually is the switch AND it is the dual pkg of switches unless you got the latest series which does not have a 3rd pressure switch. Have not had any problems with the latest version of it. THey also should be clearing the error codes off the board B4 they leave.
bcoop 01-24-2013 09:56 AM
I am having the same problem with my SLP98. I was able to get it fired up last night for about 3 hours, but the unit was off again this morning. There is no drainage issue and the vents are clear. The manual says to check the wiring for the pressure switch after clearing the vents. Is there anything else I can do before a tech arrives to eliminate everything besides a bad pressure switch?
petyanca 03-18-2013 01:49 PM
My slp98 behaves in a similar way: upon heat request the inducer spins up, and I can hear a click in the pressure switch. Then it spins for may be 20 sec, and slows down. When it slows down I can hear another click in the pressure switch. Then it stops and nothing happens. What can I do to fix this? The furnace is 14 months old. The furnace shows E228 error code on the thermostat.
yuri 03-18-2013 04:15 PM
call the installer or a certified Lennox dealer. parts should have a 10 yr warranty and there is nothing you can DIY with that furnace except check the vent pipes outside for blockage.
ahrens 03-20-2013 11:45 PM
Sounds like a bad pressure switch, they are finnicky things. Wouldve been two weeks ago now we installed a new carrier 60k btu furnace in a place ans the next day got a call saying it wont light. Was the pressure switch. Im surprised it took two different guys to figure it out though
mississippidave 12-25-2014 09:25 PM
I've had the had the same problem with my Lennox SLP98, but I have found something that worked for mine (which was installed in Nov. of 2011.
But first, the setting. Just after midnight on Christmas morning 2014 I was still up wrapping presents when I notice the air temp was cooler - checked the furnace and E228 flashing. Began the on and off every 10 minutes or so. Every Calibration cycle ended with E228. It was Christmas and a big snowstorm was on the way. No way I'm getting a serviceman on Christmas Day. So, I'm left to my own witts, and its either try the witts or have a cold family.
After checking to be sure there were no obstruction in the exhaust or intake or drainage (both ends of each and ShopVac-ing the pipes and tubes to be sure), I commenced my last ditch effort. I turned the furnace off, waited five minutes, turned it back on and waited for the CAL light on the control board (calibration cycle) to start. As soon as it started I began tapping the pressure switch very quickly with two screw drivers, one in each hand (I was a drummer in high school and have a drum set) and maintained the tapping throughout the calibration cycle....and Voila! The flame came on and the heat has been running nicely for 5 hours now.
I know, however, that I will need to put in a new pressure switch, because this will happen again. A least I have a little time now to shop for a good price. I looked at the schematics/drawing and looked over the switch carefully. It doesn't look difficult at all to change. But if I change it, the 10 year limited warranty might be nullified if it is not already from the tapping. For today, I am warm on Christmas, and this advice is my gift to y'all. Hopefully, it will help a future reader to stay warm too.
MERRY CHIRSTMAS Y'ALL!
mississippidave 12-25-2014 09:27 PM
Please forgive the typos in previous - I recently dislocated and broke my finger OUCH!
mississippidave 12-25-2014 09:34 PM
Oh, and thanks to you all for posting about this issue. Your generosity in taking the time to do so is greatly appreciated and is very helpful to many people. Thank you!
yuri 12-25-2014 11:11 PM
Yur Welcome. They won`t know you tapped it. May be cheaper to just buy the pressure switch from cozyparts.com than pay for a service call and labor for a dealer to change it. Make sure you have the COMPLETE model and serial number as there is a series number built in and they need it.
sparky90 12-28-2014 03:53 AM
[QUOTE
tapping the pressure switch very quickly with two screw drivers, one in each hand (I was a drummer in high school and have a drum set) and maintained the tapping throughout the calibration cycle....and Voila! [/QUOTE]
May I suggest drumming "wipe out" would be the best tune for success.
pingsusan 01-05-2015 08:27 PM
Thanks A LOT!!!!!
The above message worked for me as well. Thanks for posting.
dee2061 01-11-2015 12:03 PM
bad pressure switch
I have been having the same exact problem with my furnace. The last tech who came out seems like he knew what he was talking about and says it was a bad pressure switch. The first two techs found a couple leaves and believed that was problem. The last hvac company I used is a lennox dealer so the tech seemed much more knowledgeable on the unit. He said between 2011 and 2013 lennox was using faulty pressure switches in their furnaces that contained components made of tin causing them to fail after a year or two. I called Lennox directly but of course they will not tell you that. It's been almost 48 hours since the new pressure switch was installed and the furnace is still working. Keeping my fingers crossed.
Ian_R 02-24-2015 10:40 AM
Faulty pressure switch
I just had the pressure switch replaced in mine (installed 2012) this morning. The tech said he thought there should have been a recall on these but Lennox didn't/hasn't. Pretty much guaranteed to fail, he was surprised mine went this long before packing it in.
yuri 02-24-2015 11:09 AM
I think the tin story is a bunch of bullsheet. Almost all pressure switches are made by one company ( Honeywell ) as Tri delta went out of business. I doubt Lennox told a huge co like them to use tin. It is more a design concept/ fact that that furnace uses a very complex sensitive set of parameters for the setting of it. Has to do with the fact it is a modulating furnace and the couple different functions it has to do. Any tech that tells a customer his product is defective is plain stupid and would get fired in a minute where I work. Lennox probably tweaked the settings of it to make it more stable along with the programming of the circuit board/fail settings etc. Extremely complicated furnace but all mods are. I sell them and fix them and Lennox does not tell us what they do with every revision but it happens to every brand.
