Lennox Pulse Furnace Sounds Loud For The Fist Minute When It Starts Up. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 02:14 PM   #1
Lennox pulse furnace sounds loud for the fist minute when it starts up.
I have a lennox pulse furnace for the first minute of start up it sounds very loud. does the diaphragm need replaced or is it somthing else?
dhamer is offline   Reply With Quote
Old 11-22-2011, 03:39 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
could be any of a dozen different things. it should have the heat exchanger pressured tested by a Lennox tech to see if it is not cracked or leaking. he can check the diaphram at that time. that furnace has obsolete parts so I would recommend a new one.
Old 11-22-2011, 05:23 PM   #3
Pulse
Yuri is correct on this one this particular furnace was a problem and recalled at one point. Have it pressure tested by a certified tech it is possible that the welds have broken and it needs to be replaced.
FreedomAC is offline   Reply With Quote
Old 11-22-2011, 05:40 PM   #4
HvacWiz's Avatar
Rewards Points: 252
Lennox pulse = service man nightmare
HvacWiz is offline   Reply With Quote
Old 11-22-2011, 05:43 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
I was just google imaging a zone control board and came across a white van with FREEDOM A/C on it. One and the same?
Doc Holliday is offline   Reply With Quote
Old 11-22-2011, 05:46 PM   #6
Las Vegas?
Old 11-23-2011, 12:42 AM   #7
I have found over the years that the only techs that would willingly work on a pulse, would be the ones who understood the sequence of its operation, and Quite frankly its not that much different from any other condensing furnace. It has a inducer motor, it has spark ignition and a flame sensor, It has a fan/limit and some of them have a fan timer board to bring on and turn off the blower.Most younger techs fear what they do not know, i always looked at it as a chance to learn something new.
harleyrider is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 08:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Electric furnace makes loud noise like a breaker when it starts?? epyke HVAC 5 10-13-2009 05:03 PM
fan does not work in "auto" mode on my Lennox Pulse 21 gas furnace OliverMogan HVAC 1 01-22-2009 08:54 AM
