Lennox Pulse 21 Is Dead - HVAC - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 07:23 AM   #1
Lennox Pulse 21 is dead
I have a Lennox Pulse 21 that quit working so I turned off the power and then turned it back on. The LED light was off prior to doing this but once I turned it off and on the light came on and furnace worked great. It has done this several times. The last time I was able to get it to work by turning it off and on several times. But now it will come on or respond at all. This unit will not heat or cool. The LED light remains off. When the power it turned on there is a humming sound that can be heard. Any ideas where to start please?
Scenic is offline   Reply With Quote
Old 05-14-2012, 07:56 AM   #2
HVAC Tech/Owner
Rewards Points: 604
Time to put it out of it's misery....
Technow is offline   Reply With Quote
Old 05-14-2012, 08:23 AM   #3
Not really and option right now $$$ so just trying to make this one work.
Old 05-14-2012, 11:38 AM   #4
The heat exchanger on a pulse needs to
be pressure tested at least every other year. The lennox tech will diagnose the nonworking issue at that time if the exchanger passes the test. Pulses are not DIY furnaces.
The Following User Says Thank You to Marty S. For This Useful Post:
hvactech126 (05-14-2012)
Lennox Pulse Problem Cikub HVAC 3 12-11-2011 07:45 AM
Lennox pulse furnace sounds loud for the fist minute when it starts up. dhamer HVAC 6 11-23-2011 12:42 AM
Lennox Pulse, mod # G14Q3-80-13, Problems karlheppard HVAC 1 10-21-2011 10:22 PM
Lennox Pulse furnace pau HVAC 4 10-11-2011 07:59 PM
Lennox Pulse furnace air valve mekanic HVAC 12 09-26-2010 08:12 AM
