Old 07-04-2011, 09:20 AM   #1
Lennox P-8-9490 Transformer Burned Out
Two days ago I discovered my AC no longer working. The house thermostat indicated it was not receiving any voltage. I traced this back to the blower transformer which was not sending out any voltage. Input to the transformer was proper (110V).
Yesterday, in a pinch because of the holiday, I installed a Honeywell 25V 40VA transformer which I expected to work until I could get a replacement P-8-9490 transformer. The Honeywell also burned out. Is there any reason for the Honeywell to also burn out?
Harbicide is offline   Reply With Quote
Old 07-04-2011, 12:37 PM   #2
An old Tradesmen
You have a short that is burning out the transformers. must fix short before installing another new transformer.
Old 07-04-2011, 05:57 PM   #3
Hvac Pro
check the wires to the outdoor unit. may be damaged from weed whacker, dog chewing, brittle and insulation missing and shorting.
also I would splice a 3 or 5 amp GM auto type fuse with blade terminals into the wire from the trans/secondary low voltage side so the fuse pops while you are short searching. can attach the wire to the fuse with spade type stakons from radio shack or the auto parts store.
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 02:07 AM
Lennox 80MGF Board Burned out jay235 HVAC 4 12-08-2009 10:23 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
lennox 120-24v transformer zammy HVAC 5 08-08-2009 07:01 PM
