Lennox Merit Problem. - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 12:27 PM   #31
Rewards Points: 77
There IS gas feeding the valve, it's been proven by removing the hex plug on the inlet of valve.
mlijoi is offline   Reply With Quote
Old 05-10-2012, 01:04 PM   #32
I'm Your Huckleberry
Rewards Points: 2,270
Howsabout the outlet?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-10-2012, 02:33 PM   #33
Rewards Points: 77
yes, there is gas flow at the outlet too. I guess we can rule out valve now?
Old 05-10-2012, 03:57 PM   #34
Not until it's confirmed what that pressure is.
Thanks.
Old 11-02-2012, 05:40 PM   #35
Rewards Points: 77
Well, a little late to reply but it was finally fixed late last may and has been working like a charm since. One question is this. The combustion box fresh air intake is simply drawing in basement air through the black 2" intake pipe. I plan on (sometime soon hopefully) finish my basement and the furnace will be inclosed it it's own furnace/laundry room.
Will the intake need to be routed to pick up common area air? Outside air? Or just leave it alone? I was visiting a family member with the exact same unit as mine and had intake air coming from the outside. Is there any significant benefit to this?
Thanks to all who help!
Old 11-03-2012, 04:25 PM   #36
Rewards Points: 77
Hello,
Does nobody have ANY input about my concern?
Old 11-03-2012, 07:32 PM   #37
Outside air is the way to go. You wont have air seeping though cracks and crevices of the home trying to get back in to replace what was exhausted that way.
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
Lennox Merit Series Furnace - Flame Sensor?? dburell HVAC 3 12-29-2009 08:13 PM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 04:06 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
