Lennox Hs29-311 Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 12:15 PM   #1
lennox hs29-311 not turning on
I can't get my ac unit to turn on. I had to do some wire repair at the condensor. Mice chewed the wires. Now I put new terminal lugs on and hooked them back. There is a yellow,red and black wires. Can you connect these up wrong to the terminal post on the condensor? I have looked for a wiring diagram but no luck. I will also check the rest of the wiring.
Chuck
747driver is offline   Reply With Quote
Old 06-19-2012, 12:19 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Can you take some pics and post them please?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-19-2012, 08:16 PM   #3
Thanks for the wiring diagram. I found a wire disconnected on the compressor contactor. Repaired that and then turned on the unit. It ran briefly then shutoff. I then changed the compressor wires to have the 2 hot leads on the 2 top posts and the yellow ( Fan ) lead to the bottom post. I went to turn on the unit and no power. The central fan for the furnance/ac would not run either. It had been running prior to my contactor repair. Now I went out and pressed in the reset contactors the ac unit runs, but when you release them the unit stops.Somehow the thermostat circuit has quit working. There is 3 terminals on the dual capacitor. Each terminal has 3 posts. Does it make a difference as to which post you plug the wires into ?
Chuck H
Lennox Elite Series Heat Pump Model Number 10hpb24-9p Fan Not Turning On gecollins HVAC 0 04-05-2012 10:44 AM
Q for Lennox iComfort users or Lennox Pros klingon HVAC 8 02-11-2012 06:29 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 04:01 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Lennox Units not turning on Maria HVAC 1 07-28-2006 05:26 PM
