Lennox Hs26 Series Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2015, 02:13 PM   #1
Rewards Points: 2
lennox hs26 series not working
Hello I have a hs26 series lennox air conditioner. It was working the night before. I turned it off in the middle of the night and started it back up again in the mid afternoon and its not running at all. HS26-030-3P 5802B38640. it was installed on 3/21/02. The thermostat turns on and so does the furnace inside the house but the unit outside doesn't make noise or spin. I have tried the circuit brackers both inside the house and the main for the unit outside. Still nothing is working. I took pictures of the unit inside and outside. Please help with any suggestions and/or answers. Thank you, Yvonne
lennox hs26 series not working-img_0559.jpg   lennox hs26 series not working-img_0553.jpg   lennox hs26 series not working-img_0552.jpg   lennox hs26 series not working-img_0551.jpg   lennox hs26 series not working-img_0550.jpg
purdyenough is offline   Reply With Quote
Old 06-06-2015, 02:25 PM   #2
Rewards Points: 1,989
Neither the outdoor fan or compressor comes on ?
I read a thread a week or two , the guy had a similar situation . His system had a water sensor associated with the drain pan that catches the condensate off the A-Coil .
This sensor shut down the condenser . The drain line became clogged and condensate backed up in the pan .
As soon as the drain line was cleared , the condensate drained out , the sensor was once again happy and all started working again .
On the other hand , the problem may be at / inside the condenser unit .
Do you have a volt - ohm meter ? If not , you can get one sufficient for this chore at Harbor Freight .
Post back when you have a meter in hand .
God bless
Wyr
WyrTwister is offline   Reply With Quote
The Following User Says Thank You to WyrTwister For This Useful Post:
supers05 (06-06-2015)
Old 06-06-2015, 05:19 PM   #3
Rewards Points: 907
I think Wyr might be on the right track. In your last pic the black box on the floor is the condensate pump. See if that is full of water. It's a starting point.
Bitters is offline   Reply With Quote
Old 06-06-2015, 09:00 PM   #4
An old Tradesmen
Rewards Points: 6,098
There may be a high pressure switch inside the outdoor units panel. See if its tripped. Your outdoor fan may be seizing.
Old 06-07-2015, 04:40 AM   #5
Or a low pressure switch . To shut the compressor down when refrigerant charge get low .
I do not think the PO has answered if both the compressor and outdoor fan are off ?
This is easier to diagnose with a volt - ohm meter .
God bless
Wyr
Trying to decide between Lennox XC and ACX series air condensers amakarevic HVAC 3 02-24-2014 06:04 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Lennox A/C not working after power outage. Tri Boyer Appliances 0 08-24-2011 03:43 PM
Lennox Whisper Heat Furnace - G20 Series Filter Options JES1 HVAC 2 04-05-2011 12:54 PM
