Lennox HS19-411-6P - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 12:31 PM   #1
Lennox HS19-411-6P
Afternoon all!
Ive got an older Lennox ac that I think is starting to have some problems and Im not quite sure where to start. Im noticing some prolonged run times with no breaks or fairly short breaks and it cant seem to get the temperature inside below 78. Ive got the thermostat set at 75 and the temperature reads 78 so I dont feel Im working it too hard. Thoughts?
Natef is offline   Reply With Quote
Old 05-17-2013, 01:55 PM   #2
FClef's Avatar
Rewards Points: 160
Well, it is best to be certain that your filters have been changed lately. I always recommend that people change (or clean if the permanent type) their filters once a month during the heating/cooling seasons. After that, I would have someone clean the evaporator coil and the condenser coil and make sure you have enough refrigerant in the system. Dirty filters and/or coils are the most common problems so that is where I would start.
FClef is offline   Reply With Quote
Old 05-17-2013, 02:55 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Get the Freon level checked and also the compressor like a car engine will wear out and lose it's capacity. a skilled tech can check the compression ratio etc.
The Following User Says Thank You to yuri For This Useful Post:
Natef (05-17-2013)
Old 05-17-2013, 07:53 PM   #4
I just recently replaced the filter and I blow the housing out every time I cut the grass so I think my problem may be more difficult than that unfortunately. Ill get the compressor and freon checked out first. Thanks for the input guys
Old 05-17-2013, 08:44 PM   #5
Hvac Pro
yuri's Avatar
Yur Welcome
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
Which is best Lennox brand? stigwort HVAC 8 11-03-2012 06:07 PM
Undecided between Lennox 13SEER / 11EER 13GCSX or Rheem 14SEER / 12EER RRPL Sommalina HVAC 2 10-05-2012 06:51 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 04:01 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
