Lennox HS19-261 Won't Blow Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 08:11 PM   #1
Question
Lennox HS19-261 won't blow cold air
Hi all,
Anyone out there every experience your A/C Unit preferably an Lennox HS19-261 that just won't put out cold air, it's cool not cold. I've already cleaned the outside unit, don't know how to tell if the compressor is working. Thank you for your help.
eaglemaniac642 is offline   Reply With Quote
Old 05-25-2010, 08:20 PM   #2
Feel the large insulated copper line going into the unit. Should be cold but not iced. Probably low on charge. If the compressor isn't running the air coming out of the registers will be room temp, not cool.
Old 06-04-2010, 07:10 AM   #3
Thank you, now I have a new question about this, I've been told this is a closed unit so if it's not blowing cold air there's a leak somewhere & since it uses R-12 I might want to just replace the whole system. Not looking to do that yet just trying to by some time till I can replace it.
Old 06-04-2010, 02:29 PM   #4
An old Tradesmen
Rewards Points: 7,814
It doesn't use R12. Its an R22 system.
It may be low on refrigerant, it may not be.
A gas N go may get you through a year, a day, or 5 or more years.
Old 06-04-2010, 05:51 PM   #5
Yep call a tech out and have him service and fill it up if needed. Might last through the summer and it might not.
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Lennox Furnace not working when very cold bsharitt HVAC 2 02-11-2010 05:58 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
