Lennox / Honeywell Heat Pump Cycling Often - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2014, 09:37 AM   #1
Question
Hi: I have a 5 year old Lennox Heat Pump, 2 stage compressor with 2 stage aux electric heat and a lennox/honeywell thermostat. Ever since it was installed I have noticed mostly in colder weather it cycles constantly. Often it will run for a few minutes, stop for a minute or less and then cycle back on. The installer says all is correct. I just set thermostat settings 260 and 270 to 6 from the default of 9 after seeing other posts here. Any other ideas what may be happening?
miked-md is offline   Reply With Quote
Old 03-03-2014, 04:52 PM   #2
An old Tradesmen
Rewards Points: 7,328
Set your compressor CPH to 3, and your aux heat CPH to 3.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hvactech126 (03-03-2014), miked-md (03-03-2014)
Old 03-03-2014, 05:47 PM   #3
Why is the default cph for heat pump 3 and aux 9? I changed the aux cph to 6 and the difference was quite noticeable. The heat pump is running longer, but still seems to stop, wait about 30 seconds and start again. All the time it is set on 66 and always says 66. Should I also change the more or less aggressive setting? It is at the default. Thanks!
Old 03-03-2014, 05:49 PM   #4
An old Tradesmen
No, aggressive only effects recovery from set back.
Supposedly, 9 CPH is efficient for electric aux heat.
I never set aux higher then 3.
The Following User Says Thank You to beenthere For This Useful Post:
Tags
heat pump , lennox , settings
Rheem Heat Pump & Honeywell VisionPRO infoskr HVAC 2 11-20-2013 05:08 PM
Goodman heat pump - W2 wire to thermostat taxmantoo HVAC 12 07-18-2013 08:26 PM
Thermostat - Old Heat Pump to New Programmable AlexDIY HVAC 0 03-03-2013 08:17 PM
lennox heat pump shuts down sully2 HVAC 0 08-14-2011 10:48 AM
Hoewell 8000, Lennox heat pump xp15 and maintaining heat GEAF HVAC 3 01-23-2010 05:31 PM
