Lennox Heater Still Shutting Off After 10 Min - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 02:12 PM   #1
Question
Lennox Heater still shutting off after 10 min
I have a G43UF Lennox heater (6 years old). Two weeks ago, it began shutting off (after 20-30 sec) for the 3 cycles then getting the alternating red/green lights. So I replaced (NEW) the "Flame Sensor", "Ignitor", and cleaned the burner unit. The heater now stays on for 10+ min but eventually will again flame out for 3 cycles. Additionally, I've replaced the batteries in the thermostat. I'm not sure what else to repair or replace.
Danthemanjr is offline   Reply With Quote
Old 11-29-2012, 02:26 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,136
What code does it give when it flames out after 10 mins?
Old 11-29-2012, 03:04 PM   #3
I don't have it in front of me but it indicated that the problem was Heater is cycling 3 times then shut down or something else (it indicated there could be 1 of 2 problems but mine was the Shutdown after 3 cycles). The lights flash simultaneously when OK but the alternating flashes indicated the 3 cycle problem. After researching, I figured the problem was the Flame Sensor and I also changed the Ignitor but it was functioning just fine. Since I was all the way in, I also cleaned everything.
Old 11-29-2012, 08:56 PM   #4
Could have a problem with a pressure switch sticking. Pull the tubes off of them and blow through the tubes to get any debris the may be in them out.
woodsy4141 is offline   Reply With Quote
Old 11-30-2012, 10:34 PM   #5
Thank You, I will try that now.
Old 12-02-2012, 12:20 AM   #6
I know that this sounds simple, but be sure that the flame detector is clean and it is pointing at the flame.
rootboy is offline   Reply With Quote
Old 12-08-2012, 11:51 AM   #7
G43UF Lennox heater still shuting off
I have a G43UF Lennox heater (6 years old) and is still shutting off after the 4 cycles. Here's what I've done so far: changed the thermostat's batteries, replaced the Flame Sensor and Igniter, removed, cleaned and replaced the burners, all hoses, Inducer Fan and housing, drained and cleaned the condenser trap, replaced the Condensate Pump and it's still shuts down. I think all that's left is the Gas Valve and Circuit board. How can I check now what's the problem? I don't want to pay for more items and they are not faulty. I'm getting very frustrated.
Old 12-08-2012, 12:30 PM   #8
how
Rewards Points: 1,070
Yuri previously asked you what the diagnostic flash code was but I didn't understand your answer.
how is offline   Reply With Quote
Old 12-08-2012, 04:11 PM   #9
An old Tradesmen
Rewards Points: 6,132
Merged threads.
Tags
flame sensor , lennox , shut off
Lennox G23 heater randomly turns on and won't turn off kgold HVAC 6 05-20-2012 06:07 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 04:41 PM
80 Gallon Water Heater Thermostat myowneq Electrical 26 02-13-2012 11:50 AM
Lennox Heater Light flashing Jake Spain HVAC 1 12-17-2010 10:32 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
