Old 01-30-2009, 09:57 PM   #1
Default Lennox heat pump prob (update)
I posted awhile back that my heat strips kept coming on with the heat pump 3 min after startup. Turned out the temp probe selector was set at 100 deg so it was not being satisfied from the coils and the strips would kick on, now it is set at 85 and all is well, so it would seem.
Just received the elec bill again, almost $400 so im really POe'd now
I went inside the air handler and removed the temp probe and placed it just above the coils, when the compressor kicks on it's about 96 deg just above the coils so that should at least trick the probe to thinking it's all good.
Right after start up, about 1 min after temp at probe is 96 deg and the single strip is on....what's going on with this thing, can't afford this.
I removed the outside unit cover and after shut down, the alternating red LED's indicated a "short-cycle" Is this bad?
Help is greatly appreciated, won't be able to get my tech back till monday.
I wanted to add, this thing has a mind all it's own, no matter how I "play" with it, it's always one step ahead of me and knows what i'm trying to do.
I disconnected the heat strips last month and it' wouldn't turn on, fan would run but not the outside unit.
i6pwr is offline   Reply With Quote
More On This Topic
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Okay, now before we put the pork in the oven, what I have is an electronic thermometer. You can buy these at specialty stores otherwise you can get your basic pocket thermometer. So this is a very handy devise. What I'm going to do is set the temperature... Read More »
Hi, my name is Nathan McCullough on behalf of Expert Village. In these clips we're going to talk about some of the possible problems with your windshield washer system and some hints and tips to get better performance out of it. In this clip we're going... Read More »
Using Coils for Clay Bowls
Using Coils for Clay Bowls by Expert Village
Okay, now that we have the base, one technique is to use coils and what I can do is, take this ribbon tool and I can just cut them off like this. Well, that's not what I wanted to do, but that's alright. I'll just get some long strips here and just kind... Read More »
Okay our timers going off. So let's check our pork. It should be ready now. Looks good. Look at that. It's nicely browned. Temperature, internal temp is 175 so that's perfect so we will remove the probe carefully. It's a hot pan. Set that aside and we'll... Read More »
Heat Pump Woes Zenica HVAC 50 01-27-2009 09:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 09:49 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 12:28 PM
Honeywell VisionPro and Carrier heat pump ERE HVAC 0 08-07-2008 09:36 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 04:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
