Hi everyone,
First time poster , but been a lurker for while!
I have acquired two lennox heat pumps both are (HP-13 ) one is a 4 ton unit and one is a 2 ton. I would like to have the 4 ton installed in conjunction with my current propane furnace ( a keeprite 9MPV075 ) . Problem is the installer said that my house/furnace will not handle a 4 ton due to lack of CFM and is more suited to a 3.5 ton unit. I got a good deal on these units and was wondering if there is a any way to derate the 4 ton unit or incrase the CFM output on my current furnace. I have a newer home 2000 square very well insulated.
Thx Beenthere
The model number is C9MPV075F12D i have the manual but dont fully understand what im looking for .If im reading it correct it can handle a 3.5 ton cooling unit. My house is a 4 level split with a halve the house having 16 foot ceilings so there is a fair bit of space to condition.
If it was just the furnace and indoor coil. With no duct work on the supply or return. It could move enough for 3.5 tons. But you got duct work. So nope. Ain't gonna work right.
Space is not as relevant as you might think. Unless you have a lot of air infiltration. Meaning your house isn't constructed real well. In which case. Improving your homes envelope is the first thing to do.
Might want to do your own load calc, and see what size you really need.
But as accurate as possible. And don't fudge any numbers. HVAC Calc . Its worth its 49 dollar fee.
And much cheaper then new duct work. Or replacing compressors.
Thx Is the 2 ton unit worth trying? Our main objective is to add some cooling to the house and offset some heating cost. We do not like it really cool in the summers just want to keep below 75.
I used the program best thing I ever did the installation company was going to install a 2.5 to heat pump after doing the calculations I quickly realized that a 3 ton was needed. Company was emberrased and only charged my a minimal fee for upgrade:thumbup:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
