Lennox H522-261U-2P Central Air Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 02:57 PM   #1
Question
Lennox H522-261U-2P Central Air unit
Hello, my name is Mark. I have an older Lennox H522-261U-2P Central Air unit. It stopped cooling the other day. I found the blower fan in the compressor unit was gummed up. I took it apart and cleaned it. The fan is working now. However, when I turn down the thermostat to where the compressor and fan should turn on they do not. There is a solenoid in the compressor unit that is controlled by a timing circuit board, which fires the fan and compressor. The solenoid does not close when I turn the thermostat down. I can manually engage the solenoid and the system runs, and will cool as normal. I suspect the timing circuit board is the problem. Has anyone experienced this. Am I on the right track here. Let me know
mandvinmpls is offline   Reply With Quote
Old 07-02-2013, 03:09 PM   #2
Question
Old 07-02-2013, 03:51 PM   #3
Try pushing the red button on the high pressure switch.
Old 07-02-2013, 04:20 PM   #4
Thank you. Excuse my ignorance but is that in the heat pump unit. I didn't see anything like that in the compressor unit
Trane Central Air Unit hellawear9 HVAC 0 06-10-2011 12:50 PM
Lennox A/C unit not starting netddd HVAC 8 08-17-2010 12:30 AM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
Removing Refridgerant from Central Unit wackerjr HVAC 1 06-23-2006 03:09 AM
Need to remove old central air unit pmb003 HVAC 4 05-03-2006 05:05 PM
