Lennox Gas Fireplace Draft - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 05:34 PM   #1
Rewards Points: 12
Hello,
I have a Lennox LMDV-3530CNM. This is my second winter in the home and first doing the startup. While cleaning out the lower compartment prior to lighting I noticed a draft in that area near where the gas line comes in.
My question is can I put insulation around the gas line or take other steps? Thanks?
cs006b is offline   Reply With Quote
Old 12-21-2010, 03:45 PM   #2
Rewards Points: 12
If there is a type of insulation I can use please advise the best type. Thanks
Old 12-21-2010, 05:18 PM   #3
Don't know about the rest of the guys but around here fire places are considered decoration and not heating equiptment. Not covered on HVAC permits or inspections so we don't mess with them. That might be the cause for no answers.
Old 12-21-2010, 06:04 PM   #4
An old Tradesmen
Rewards Points: 7,256
I don't work on them. So I can't give a good answer as to weather or not sealing that hole would hurt anything or not.
Where does it get its combustion air from?
Old 12-21-2010, 06:09 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
Looks like a sealed comb unit with that intake within the exhaust pipe concentric termination. I have seen a few. If you seal that hole and it gets cold in there moisture may condense and cause a problem. I would leave it alone and lets some heat in. Those units rusty easily inside and out and I would not want a condensation/cold problem to be created.
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Yuri Help! look please - lennox g26 draft inducer motor drain? mjt57 HVAC 6 02-06-2010 04:41 PM
lennox g26 draft inducer squeals mjt57 HVAC 3 02-04-2010 04:13 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
