-   -   Lennox G61MPV - is a very slow fan speed possible (http://www.diychatroom.com/f17/lennox-g61mpv-very-slow-fan-speed-possible-167740/)
lbuser 12-29-2012 10:32 PM
I have a Lennox G61MPV-36B-071-12 gas furnace. As best I can understand from the manual the low speed fan air flow is around 700 cfm. That causes quite a draft of cold air when the fan runs (without heat) by itself, pulling air in from outside. As a result, we don't use it as a means of fresh air circulation. If the fan could be slowed to say 150 cfm then the draft feeling would be less noticeable. Is it possible to do that? And if so, how? It has an ECM (I think that is what it is called -- low energy consumption, variable speed) motor.
I am considering adding an HRV to warm the incoming air to reduce the cold draft feeling further. It would tap into the cold air return for both outgoing and incoming air. I understand that the air handler on the furnace needs to run when the HRV is configured this way. Thus the reason for lowering the furnace fan speed to that of the HRV, which is 150 cfm.
carmon 12-29-2012 10:57 PM
no it is not possible...... 700 cfm does sounds hi..... I believe the lowest continous fan is 30% of 2nd stage cooling speed.... others will chime in..getting old memory failing......:(
lbuser 12-29-2012 11:53 PM
Thanks carmon
I was hoping it would be possible since it is a variable speed electronic motor.
I guess the next angle to pursue would be if I could have just the 150 cfm HRV distribute fresh air through the duct work without the furnace fan needing to be used. (The furnace doesn't run much as we are on the west coast and the gas fireplace does a lot of the heating - less efficient than the furnace I know but a big pleasure.)
carmon 12-30-2012 12:21 AM
hrv wont push air far enough..... furnace fan distributes air....
beenthere 12-30-2012 01:50 AM
If you have only one return for your furnace, have the HRV's stale air inlet installed in a hallway, and its fresh air discharge installed into the furnace supply plenum/duct.
If your gas fireplace gets its combustion air from the home. then using it is what is causing so much cold air to be brought into the home.
yuri 12-31-2012 09:04 AM
Actually it is possible. They are set from the factory for around 450 cfm for low speed. On those furnace if you look very carefully inside the viewing port on the lower door there should be a small series of red LEDs. There is a way to read the fan speed but you need to read a service manual. If I remember you count the flashes and each flash is 100 cfm and then there is a pause and it starts over again. If it is higher than 4-500 then the installer changed it and it can be put back down by flipping some dip switches.
beenthere 12-31-2012 03:51 PM
Ain't gonna get it down to 150 CFM like he wants.
carmon 12-31-2012 03:54 PM
I trust ya man....... but never seen one supply 150 cfm....... you know something I don't
yuri 12-31-2012 04:02 PM
I said it could go down to 450 not 150 which is impossible. I doubt he will feel drafty at 450 as we sold 1000s of them and a lot to elderly people and not one complaint. Actually I can tweak that down another 10-15% with the dip switches too.
carmon 12-31-2012 04:06 PM
his question was is 150 possible.... I ....said its not..... you said it is..... never mind Just kidding.... have a happy new year Yuri
yuri 12-31-2012 04:14 PM
No problema. 450-10% should make him Happy. Hopefully the Next Yr is a good one. Health wise the last one has been horrible. Freedom 55 cannot get here soon enough.
carmon 12-31-2012 04:17 PM
I hear ya man.... we had a great year moving into new housing..... very lucky to have a few great builders that pay there bills..... and the Lennox Line has been flawless..... zero failures in 3 years.... yes 100% zero failures....
beenthere 12-31-2012 04:26 PM
As Carmon said, he was asking for 150. Thats why i said ain't gonna happen.
Sorry to hear about your health.
carmon 12-31-2012 04:28 PM
Ya me to ...... sure hope you are feeling better..... you are a smart tec..... love reading your posts..... stay healthy :thumbsup::thumbsup::thumbsup:
yuri 12-31-2012 05:12 PM
Thanks for the wishes. Gotta stop running around like Superman trying to solve everyones problems around me.
