Lennox G51MP Elite Series - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 10:27 PM   #1
Go Riders
Good Evening:
I have a Lennox G51MP furnace that has quit working tonight.
The LED diagnostic code states primary or secondary limit switch open. Limit must close within 3 minutes or unit goes into 1 hour Watchguard
I don't know what that means.
I have taken the covers off and cleaned things up a little.
When I put the cover back on, the fan starts but only lasts for about 3 minutes. No heat is produced.
I have also turned the Thermostat off and back on again after a few minutes.
When the thermostat is off, the sure lights state normal operation.
turn the thermostat back on and I get the error again.
The Cat Man is offline   Reply With Quote
Old 11-15-2010, 06:16 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,282
It means that the limit control above the burners has failed open from the furnace continuosly overheating from a lack of airflow.
Old 11-15-2010, 06:39 AM   #3
Go Riders
Thanks Yuri
any idea how to fix it
Old 11-15-2010, 04:36 PM   #4
Hvac Pro
yuri's Avatar
Do you own a electrical meter/multitester and know how to check voltages and continuity?
Old 11-15-2010, 04:45 PM   #5
Go Riders
Yuri:
I just reset the primary limit switch by pulling off the ground wire and putting it back on.
that's all it needed I guess.
It was caused by the lack of airflow like you said and when the new filter didnt help......I was a little concerned
All is well now and we once again have heat in Regina.
Old 11-15-2010, 05:25 PM   #6
Pulling the wire probably jiggled it enough to work for now. Sometimes a screwdriver tap will do the same. I never trust them after that and always order a new one to be safe.
Old 11-15-2010, 05:30 PM   #7
Hvac Pro
yuri's Avatar
Yep. Not sure if you can order them online in Canada but Cozyparts.com in the US has them and so does your local Lennox dealer. MAKE ABSOLUTLELY sure you do not stick it in upside down or it will fail. Note how the old one was installed. Check the temp rise thru the furnace. Subtract the return air/house temp from the supply air temp measured a foot downstream from the plenum with a cooking thermometer stuck in the duct. Then check the specs on the rating plate inside the furnace ie: 50-70F. If it is overheating then the fan needs speeding up or the ductwork fixed. Too bad our Bombers bombed out. Go Banjo pickers
Old 11-15-2010, 05:43 PM   #8
Go Riders
Thanks for your help guys.
Go Riders.
Did you watch that game last night!!
Do you get TSN in Winnipeg??
Old 11-15-2010, 05:49 PM   #9
Hvac Pro
yuri's Avatar
We get TSN but I don't watch too much football with our miserable bums. Now they are building a $200 million stadium for the sad sacks. Was watching Battle of the Blades on CBC. Hockey players on figure skates, go figure, must be Canada eh!
HELP- Lennox Elite Series Furnace # M/N 90UGFA3-75-5 baironhorse HVAC 41 10-22-2014 03:59 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 02:49 PM
lennox elite series g26 moon4040 HVAC 4 10-21-2010 05:16 PM
Lennox elite series 90 UGF beenieb HVAC 1 10-20-2010 09:38 PM
Lennox Elite Series - right fast flashing light. Need Help natemast HVAC 4 10-03-2010 04:55 PM
