Old 03-19-2012, 09:06 PM   #1
Lennox G50UH(X) series LED indicator
Hi, I have one of these furnaces and it stopped working yesterday. I have tried everything to reset it and they didn't work. Today I went up in the attic and checked the LED lights and they were flashing to indicate;
1.Improper main ground
2.Broken ignitor; OR: Open ignitor circuit
3.Line voltage below 75 volts
It has been working fine for quite a while...
I did let the filter get pretty dirty and a friend said it is likely one of the sensors got dirty as a result. My question is which one and where do I find it?
(I have replaced the filter and need to get it turned back on ASAP)
Thanks.
littlepilgrim is offline   Reply With Quote
Old 03-19-2012, 09:45 PM   #2
how
I would start by
(1) Checking all ground wires connections from board right back to the circuit box.
(2) checking igniter....
Unplug ignitor and read resistance across ignitor. If resistance does not read between 10.9 and 19.7 ohms, replace the ignitor.
If igniter is OK - check for bad connections on ignition circuit.
(3) Check what the L1 line voltage to neutral at the board is.
how is offline   Reply With Quote
Tags
dirty sensor, g50uh(x), led indicator, lennox
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
lennox elite series wesley01 HVAC 1 01-13-2011 05:04 PM
Lennox Elite Series Furnace Will not Light xchvyragtopx HVAC 2 01-10-2011 08:36 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 03:49 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
