Old 09-27-2012, 10:27 PM   #31
I'm Your Huckleberry
Lennox G50 wont ignite. Pressure switch is ok, intake clear, exhaust clear too
If the inducer is coming on no need to jump it. Fix air leak/casket.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-27-2012, 10:29 PM   #32
Gasket.
Thanks.
Old 09-27-2012, 10:38 PM   #33
Yes I will. Again thanks for all the help. This is the prob. A new motor costs 110$ so this saved me some coin.
Muzzle127 is offline   Reply With Quote
The Following User Says Thank You to Muzzle127 For This Useful Post:
ben's plumbing (09-27-2012)
Old 09-27-2012, 10:48 PM   #34
Need to use high temp silicone.
Thanks.
Old 09-28-2012, 12:02 AM   #35
Almost a bird! I was close. Ya, I know..this aint horseshoes...
techpappy is offline   Reply With Quote
Old 09-28-2012, 04:03 PM   #36
What material is that gasket made of? Some type of non asbestos hi temp material. Cant find the gasket anywhere. I went to O Reilly auto parts and could buy a sheet gasket and cut my own. Any suggestions?
Old 09-28-2012, 08:05 PM   #37
not sure but may be ceramic fibre material which would be suitable and may be available at heating supply or Big BOx store?
Old 10-15-2012, 10:35 PM   #38
Worked for a while but stopped again. Took apart again. Inducer hub set screw is slipping now. I will try to tighten. This may have been the problem all along why air was not being drawn.
Old 10-15-2012, 10:43 PM   #39
if there is room try to install one set screw on top of the first one ...that will lock it in place
even if you have to buy shorter set screws
Old 10-16-2012, 12:52 AM   #40
It is easy to spin the balancer black plastic end by locking up squirrel cage. The set screw is solid. The shaft wobbles alot and is out of balance. I think the inducer bearing is shot. Geez what an ordeal this is. Im just gonna replace the motor
Old 10-16-2012, 09:16 AM   #41
Agree...Its time to replace
The Following User Says Thank You to techpappy For This Useful Post:
Muzzle127 (10-19-2012)
Old 10-18-2012, 08:09 PM   #42
Inducer motor showed up today. Installed in 30 minutes as I am now proficient at taking my furnace apart and re assembling it. Burners fired up again. Ah sweet heat.Just before it gets really cold. Thx
ben's plumbing (10-18-2012)
Old 10-19-2012, 07:59 AM   #43
Great to hear. It is a great feeling when you are now the master of the beast.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 10-19-2012, 08:18 PM   #44
Plenty of guidance was given here. With all the help, I ran it to a close on my own schedule. Didn't miss any work at my day job and the repair wasn't overly costly to complete. Now the after party!!!
No Heat: Pressure switch & Hoses forming traps Yooperman906 HVAC 22 01-04-2011 10:52 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Comfortmaker RPJ II Pressure Switch hansolos HVAC 3 02-24-2010 07:50 PM
Help a hungover guy clear his head. 3 way switch with pic J187 Electrical 10 11-10-2006 09:10 PM
