Lennox G40uh Replaced Control Board With 83m00 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 08:24 PM   #1
Lennox g40uh replaced control board with 83m00
I need some help please. I replaced my SureLight control board in my Lennox g40uh furnace with Surelight 83m00 control board. I turn the power on and get the display 1 and display 2 lights blinking together. However, nothing comes on. The only thing that did not get moved from the old board to the new board was a fuse that was plugged into the old board. I did not see a place to put it in the 83m00 board.
dpledge is offline   Reply With Quote
Old 03-30-2013, 03:54 AM   #2
Houston204's Avatar
Rewards Points: 556
Is the door switch depressed?
Did you connect the stat wiring?
Is the stat calling for fan, heat or cooling?
Does the fan start when you jumper R to G?
Does the induced draft motor start when you jumper R to W?
Do you have a digital camera so that you can post pictures of your wiring?
Houston204 is offline   Reply With Quote
Old 03-30-2013, 08:56 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,858
where did you get the board? I am 95% sure it is the wrong one. G40 uses a different voltage /size igniter than the G50 and others that can use that retrofit board. cozyparts.com for lennox parts
Troubleshooting Ignition Control Board and Ignitor damnyankee36 HVAC 1 12-30-2012 04:55 PM
No LED on 350MAV Control Board samworkss HVAC 32 11-29-2012 07:42 PM
lennox mgf3-60a-7 control board dewey7015 HVAC 7 12-19-2011 07:08 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
