Old 05-20-2012, 01:39 PM   #1
Fire Alarm Technician
Question
Lennox G40UH - No Cold Air!
I have a Lennox G40UH 361-070-03 with a 10ACC-030-230-01 and the furnace is running however I'm not getting cold air. I went outside to the condenser to find that the fan was not running and the motor was hot to the touch. I found that I could start the fan by hand. I shut everything down for about 30 minutes and then turned it back on, started the fan by hand and let it run for about 10 minutes. I then did a temperature reading on the compressor and it was hotter then out door temperature. I'm wondering if I have a bad run capacitor, or is it worse than that. Any help would be greatly appreciated. Thanks so much.
cpd
cpdavey is offline   Reply With Quote
Old 05-20-2012, 06:22 PM   #2
Sounds like a bad capacitor.
clocert is offline   Reply With Quote
Old 05-21-2012, 09:06 PM   #3
Thumbs up
clocert -
I had just changed it out when I got your response. That's exactly what it was. I'm so glad it wasn't worse. Thank you so much for your response.
cpd
Tags
hvac compressor, no cold air, run capacitor
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
Only hot or cold water DiyPadawan Plumbing 8 10-20-2010 09:13 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 12:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
