Old 10-21-2011, 07:43 PM   #1
Lennox G40UH-48B furnace burners failed to light
LED trouble code is "burners failed to light" but they do light and burn for 30 seconds then a click and they shut off. Cycle repeats 4 times and then lock out. I replaced the return air filters and flame sensor with no change. Both fans run fine.
PAULROB1 is offline   Reply With Quote
Old 10-21-2011, 09:05 PM   #2
An old Tradesmen
Could be a poor ground.
Old 10-21-2011, 09:20 PM   #3
JJboy's Avatar
check the service manual ==> http://www.google.com/url?sa=t&rct=j...476QDA&cad=rja
You can try to clean the burn and check the igniter
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 11:46 PM
Burners Won't Light on Trane xl90 ma2willnjack HVAC 4 10-04-2011 07:50 PM
Lennox Elite Series Furnace Will not Light xchvyragtopx HVAC 2 01-10-2011 08:36 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
