Old 07-17-2011, 02:51 PM   #1
Question
Lennox G27M fan will not stay on.
A couple of weeks ago, I noticed a pulsating sound coming from my vents. What I found is that with the AC on or FAN on, the fan is not staying on consistently.
The fan will shut off, I hear clicking in what I am guessing to be a relay, and the diag lights switch from a simultaneous blink to a solid green. After a second or two, the fan tries to restart, the diag lights switch back to a simultaneous blink. Sometimes it stays on for a few minutes, other times it will try 4 or 5 times to restart. Sometimes it will restart and keep operating as normal.
If I turn off the electricity to the furnace and then turn it on again, it will run normally for about 5 minutes. It does seem that the longer I leave the unit off, the longer it will run.
I replaced the air filter about a week ago in hopes of helping the situation, but it has not.
So I am looking for thoughts on what I should check next and how to check it. Any help would be appreciated!
RockCityGhost is offline   Reply With Quote
Old 07-17-2011, 03:26 PM   #2
Hvac Pro
solid green means control board failure. sounds like the board is malfunctioning/dying. may want to get an experienced Lennox tech to check it. may have bad grounding. the replacement board is usually/probably a retrofit and difficult for the average tech to rewire and beyond most DIYers.
Tags
blower fan stops, clicking, help please, lennox, relay
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Lennox Furnace burner won't stay on stevea7777 HVAC 43 01-07-2013 03:17 PM
Lennox Conservator II Won't Stay Lit bkrinke HVAC 11 01-21-2011 01:09 AM
Lennox Whisper Heat burners won't stay lit Gaff519 HVAC 2 12-09-2010 12:32 PM
Help with lennox furnace will not stay on. slowhand HVAC 4 12-06-2009 09:10 PM
