Lennox G26Q4/5-125-6 Help - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 01:45 PM   #1
Lennox G26Q4/5-125-6 help
I am a service manager at an apartment complex and the furnace that is having the problem turns the induced draft fan on for about 1 second and then turns off and wont turn on until I reset it. I replaced the draft fan but that turned out to not be the problem. the board flashes the green lights after the fan turns off..
If anyone can help it would be greatly appreciated.
diamondbackk60 is offline   Reply With Quote
Old 12-16-2010, 02:00 PM   #2
BIGRED
Rewards Points: 252
The flashing lights are an error code that applies to your brand and model of furnace. You must find the error code chart, either in your papers or on line and determine what the little guy is upset about. While you are at it call a local Lennox dealer and get them out. If you just can't wait, check the furnace flue. If the induction fan runs on call for heat for a few seconds and quits I would suspect that there is some form of flue blockage. Might be near the furnace or an animal could be caught in the chimney. The last time I ran across this I found a 2" galvanized flue pipe at the furnace connection choked down to about 3/4" with dirt and rust inside the flue.
Grampa Bud is offline   Reply With Quote
Old 12-16-2010, 03:09 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
Read the error code chart and report back. Sounds like the ventor fan relay is failing on the board and need a new circuit board. Try cozyparts.com
Old 12-16-2010, 03:32 PM   #4
checked the vent but nothing is clogged. I have looked everywhere for the error codes but cant find them. Anyone have suggestions where I could find these error codes?
^^^ Disregard above I got it figured out, thanks everyone for your help!
Old 12-16-2010, 03:48 PM   #5
Hvac Pro
yuri's Avatar
They are usually on a sticker on the inside or outside of one of the furnace doors.
Tags
g26q4/5-125-6 , lennox
Lennox Furnace 80UHG3 Won't Ignite KeithGP HVAC 8 03-22-2014 12:22 PM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 03:35 PM
Lennox AC BlueBSH HVAC 1 05-10-2010 04:51 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
