Lennox G26Q3-75-1 Furnace Does Not Fire Up - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 08:01 PM   #1
Lennox G26Q3-75-1 Furnace does not fire up
The furnace fires up when you turn it on, but does not fire up in subsequent cycles. Need to turn it off and on again for it to fire up.
Mary3009 is offline   Reply With Quote
Old 10-22-2012, 08:18 PM   #2
how
Rewards Points: 1,104
Is there a flashing led diagnostic light on an electronic board that is visable through a viewing port in the door?
There should be a legend in the furnace that will explain those flashes.
how is offline   Reply With Quote
Old 10-22-2012, 08:27 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
http://hvacpartsshop.net/G26_Series.pdf
when it does not "fire up" what does it do? IOW, sit in front of the furnace and tell us the sequence of events that happen with a call for heat when the unit does not "fire up".
As how said, diagnostic flash codes can give you a clue as to why the furnace does not work.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-22-2012, 09:58 PM   #4
That would be a lock out,turning the power off resets it. Weak flame sense from dirt and rust on the burners and flame sensor would be my guess. When you pull the burners out to clean them look into the heat exchanger for cracks.
If it still has the original blue johnson controls ignition module that's probably one problem.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Comfortmaker furnace won't fire Scott Little HVAC 26 09-23-2010 07:38 PM
Lennox Furnace not working when very cold bsharitt HVAC 2 02-11-2010 05:58 PM
Portable generator and Lennox furnace joshbloomberg Electrical 7 02-10-2010 10:25 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
