Lennox G26q3/4-100 Crack? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 07:22 PM   #16
Aire Flo is cheaply made for the economy market. See alot of them every summer and they are mostly under five years old. They seem to be the favorite of the less skilled unlicensed tech who cater to a very low end market.
hvac5646 is offline   Reply With Quote
Old 01-09-2012, 07:23 PM   #17
Agreed. If quiet and comfort is what you want get a two stage in the Lennox signature series. Don't think I'd go so far as to call the air flow pure crap but it's too noisy for my taste.
No sence in putting in a control board and a heat exchanger in that old G26. That will be close to a $1000 that would be better spent on a new furnace.
Old 01-09-2012, 07:29 PM   #18
Rewards Points: 1,778
Yuri; any thoughts on which York? (I believe you are a York dealer?)
bob22 is offline   Reply With Quote
Old 01-09-2012, 07:36 PM   #19
Yuri and I work for Lennox dealers. I believe beenthere is a york man.
Old 01-09-2012, 07:40 PM   #20
Marty,
Thanks; makes sense I guess with Beenthere from Lancaster and York is from York (nearby in PA)!
The Following User Says Thank You to bob22 For This Useful Post:
ben's plumbing (01-09-2012)
Old 01-09-2012, 07:47 PM   #21
Hvac Pro
yuri's Avatar
Rewards Points: 402
If you can get your hands on a Lennox G61V 2 stage unit as very soon they are being replaced with an EL295V unit the G61V is bombproof and tried tested and true for 8 or more yrs and very dependable as any wrinkles have been worked out. Most Lennox techs know them very well also so getting an experienced tech is not hard, unlike some of the higher end mod units. York makes good units but I am not familiar with their specific models. AirFlo is a builders grade unit that works well but can be a bit noisy. Kinda like a Kia, owned by Hyundai but not to the higher end Hyundai standard.
The Following User Says Thank You to yuri For This Useful Post:
Old 01-09-2012, 07:58 PM   #22
Thanks Yuri and everyone so far. I'll wait on Beenthere's or another York person's perspectives before moving forward.
Off to watch some TV.
Old 01-11-2012, 01:40 PM   #23
Results of my manual J using software from HVAC-Calc:
Design conditions:
Philadelphia
Indoor:
Summer temperature: 72
Winter temperature: 72
Relative humidity: 50%
Outdoor:
Summer temp: 90
Winter temp: 14
Summer grains of moisture: 102
Daily temp range: Medium
Whole House: (in BTUH)
Sensible gain: 33,974
Latent gain: 7,188
Total Heat gain: 41,162 (3.5 tons)
Total Heat loss: 50,284
Total sq ft: 1,911
If I change the Summer temp to 95*, then Total Heat gain goes to:
43,948 (3.5 ton)
42,569 with 90* and 70* indoor temp.
So, I'm assuming that a 3.5 ton unit is correct for cooling? Current Lennox is I believe 46k BTU (model HS23-461-2P).
For heating, current furnace is 100,000 90% Lennox. If the Manual J is right, then it is oversized by almost 50%, agreed?
Current suggestion from my HVAC guy is an 80k, 98% York with variable speed fan for noise reduction/comfort.
Any suggestions from you guys as far as sizing and/or models (esp. York's TM9V,T, or X or another?)?
Thanks,
Bob
Old 01-19-2012, 06:30 PM   #24
Update:
The HX did have a crack in it although further back than what I could see from the burner tube opening:
Lennox G26q3/4-100 Crack?-crack-800x600-.jpg
I also saw one of the rings that popped off where the HX sides are connected lying in the bottom of the unit. You can see where the holes are that the rings are missing:
Lennox G26q3/4-100 Crack?-img_0240-800x600-.jpg
The new York unit is installed; guys did a great job and I learned first hand on how to install a unit correctly and how to make a transition boot with sheet metal from sheet stock.
Thanks to all (especially Yuri and Beenthere) who helped with the decision-making. She now has a variable speed motor, two-stage 80K unit (down from 100K) with a new thermostat that works with the unit, and a new, correctly sized A-coil. All for $3300 + $80 inspection (5 minutes: "Looks great, very nice, neat work") and $50 for the thermostat. Local utility rebates $300 for the furnace.
Old 01-19-2012, 11:58 PM   #25
Originally Posted by bob22 View Post
Update:
Attachment 44347
Attachment 44348
that unit was over fired......
harleyrider is offline   Reply With Quote
Old 01-20-2012, 06:02 AM   #26
Agreed, although it did last 17 years.
single horizontal hairline crack in stucco mark_goal Building & Construction 0 04-06-2011 12:36 PM
Cracks in 10 yr old house drywall tenthirtytwo Drywall & Plaster 9 03-15-2011 11:33 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Crack in Cast-Iron Wye sonofthetonsured Plumbing 16 01-15-2010 07:10 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
