Lennox G26 Water Leak At Botttom Seam Of Air Combustion Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 10:40 PM   #1
Question
lennox g26 water leak at botttom seam of air combustion blower
flue y trap successfully replaced and that leak stopped, now water leaks from bottom seam of air combustion blower. All hoses are clear. Is there a surface sealer that will work for this?
pdzd is offline   Reply With Quote
Old 12-01-2011, 06:34 AM   #2
Silicone
Old 12-01-2011, 07:05 AM   #3
Question
re: reply silicone
the air combustion blower motor gets pretty hot, so silicone can handle the heat?
Old 12-01-2011, 08:52 AM   #4
yes....use 100% Silicone.....(smells very much like concentrated vinegar). The only way to do it right is to take the assembly off the furnace split the two halves remove any remnants of the old seal, apply a new bead of silicone all the way around put the two halves back together and let it set for 4 to 6 hours to set up (this entire time you have no heat) while your waiting for the silicone to set up its a good time to remove the old gasket from the collector box and apply the new gasket......wait a minute....."were do I get a new gasket ?" you ask...........it comes with a new combustion motor assembly......
harleyrider is offline   Reply With Quote
Old 12-01-2011, 11:58 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
heat it gently for a few mins with a hair dryer (wish I had some hair to dry ) or a heat gun and put some silicone on it and hope it cures or do it in the summer when it is not running. lots of times those leaks seal themselves with water mineral and if you put a pan or towel there and wait a month it may seal itself.
Old 12-01-2011, 12:07 PM   #6
Or it may drip on to the main circuit board and short it out.......so I have to ask......"are you feeling Lucky today"?
Old 12-01-2011, 12:11 PM   #7
Hvac Pro
yuri's Avatar
Its a DIY save a buck world.
Best bet is to get a new inducer from cozyparts.com and replace it. Those units are NOT repairable and separable as you cannot remove the specially factory pressed/sealed on impeller from the motor shaft. silicone rarely seals them and replacing it is the best option.
Old 12-11-2011, 08:05 AM   #8
just installed new 59m03 now water is dripping out of lower seal at tighltly clamped black tubing help please
Old 12-11-2011, 08:32 AM   #9
Hvac Pro
yuri's Avatar
post a pic of that. I work on lots of those units and Marty also.
Old 12-11-2011, 08:53 AM   #10
No pic leak is at bottom of the new flu were it connects to the outlet of the combustion air inducer by a worm gear clamp over a rubber sleeve the clamp is as tight as i can get it
Old 12-11-2011, 09:05 AM   #11
Hvac Pro
yuri's Avatar
that is rare and I change lots of them. need to remove the fan and check for a wrinkle/damage to the boot or maybe there is a ridge on fan outlet from manufacturing. you can remove it and dry it and put a thin layer of red rtv silicone on it and reassemble let it cure for several hours. the clamp can get seized up/not tightening properly so you may want to replace it. Hdepot or plumbing supplier for that.
Tags
lennox g26
Heil GNE075B12 Water in teh tube between combustion blower and pressure switch Quin HVAC 51 01-04-2013 11:46 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Mysterious Water Leak Georgia2010 Plumbing 5 12-23-2010 10:02 PM
