Old 11-29-2011, 07:48 PM   #1
Lennox G26 Furnace
The furnace control board has no activity on it's LEDs. I have no command of heat, cool, or fan. I started with resetting the breaker, then tried a new digital thermostat. I also tried attaching the thermostat to the furnace with a new piece of 24" wire to try and eliminate a short. I checked power to the door switch and checked fuse and all seem good. I have the same power input level from door switch to circuit board to transformer line in. I have zero power coming out of the transformer load. I have tried a new circuit board which bought me to a new model 83M00. This replacement board has a yellow/green wire that is extra, there was nothing in the install directions regarding this wire. I have also tried a new transformer. What seemed like an easy, logical fix has not turned out to be so. Any suggestions would be appreciated, I don't think our space heater is going to keep up with the arctic chill headed our way. Thanks.
bucks454 is offline   Reply With Quote
Old 11-29-2011, 07:51 PM   #2
Lennox G26 Furnace
Do you posses and know how to use a VOM meter?
harleyrider is offline   Reply With Quote
Old 11-29-2011, 08:00 PM   #3
Unhappy
Lennox G26 Furnace
I do have a meter, I would not say I'm an expert at using it.
Old 11-29-2011, 08:02 PM   #4
Lennox G26 Furnace
well, i need to know how much voltage is going INTO the transformer, If you don't have enough going in you will get nothing out.Put the meter on VAC and measure the voltage between L1 and L2.Remember to have the door switch depressed or taped or whatever........
Old 11-29-2011, 08:13 PM   #5
Lennox G26 Furnace
L1 & L2 measure the same .580v
Old 11-29-2011, 08:18 PM   #6
Lennox G26 Furnace
How's the little black low voltage breaker?
BTW the yellow and green wire goes to chassis ground
Old 11-29-2011, 08:19 PM   #7
Lennox G26 Furnace
there u go.......if you measured correctly , you don't have any high voltage. Possibly a bad door switch, bad ssu , blown fuse or tripped breaker. I just want to make sure that you measured correctly......you have a black and a red lead on your meter, and its set to VAC and you put one lead on L1 and the other on L2 and got.058 ?
Old 11-29-2011, 08:19 PM   #8
I'm Your Huckleberry
Lennox G26 Furnace
Harley, meet bucks454.
manual. http://www.lennox.com/pdfs/manuals/L...G26_Manual.pdf
Doc Holliday is offline   Reply With Quote
Old 11-29-2011, 08:30 PM   #9
Lennox G26 Furnace
Originally Posted by Doc Holliday View Post
Thanks Doc, I think I could recite that manual by memory..............lol, maybe the client will find it use full though.
Old 11-29-2011, 08:35 PM   #10
Lennox G26 Furnace
I placed the black electrode on ground and red to L1 and L2 individually. When I placed black on L1 & red on L2 the meter read. .000. Individually each read (.580v)
I have a yellow/green to chassis ground already I guess I could put the other down as well.
Old 11-29-2011, 08:41 PM   #11
Lennox G26 Furnace
The black breaker is connected to transformer load and is receiving no power. It seems power is stopping at transformer. Maybe I connected this wrong? It seems like that is not possible because the tabs are of different sizes.
Old 11-29-2011, 08:47 PM   #12
Lennox G26 Furnace
You should have 120 volts instead of.058
Try L1 on one meter lead and the other meter lead to ground. If you get 120V that way the the neutral wire going to the furnace is broken.
The Following User Says Thank You to Marty S. For This Useful Post:
Doc Holliday (11-29-2011)
Old 11-29-2011, 08:47 PM   #13
Lennox G26 Furnace
You have no power going to the transformer.
please check the power like i told you to do in a previous post......its important that you do exactly as i tell you so we are not missing something
"......you have a black and a red lead on your meter, and its set to VAC and you put one lead on L1 and the other on L2 "
do not check it to ground.
Old 11-29-2011, 08:53 PM   #14
Lennox G26 Furnace
Okay, I have to ask. Is this is a 120 volt gas furnace or a 240 volt electric air handler? No, I haven't checked the manual.
What are we looking for across L1 and L2 and why not to ground? Tells wonderful tales, to ground.
Old 11-29-2011, 08:56 PM   #15
Lennox G26 Furnace
Its gas, and reading from L1 to L2 will give you your potential voltage, reading to ground will vary and can be deceiving.
The Following User Says Thank You to harleyrider For This Useful Post:
Tags
furnace control board, lennox, transformer no load
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 05:38 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 09:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 07:52 PM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 06:51 PM
Lennox G11Q3E-110V-6 gas furnace neato5oh HVAC 1 10-07-2006 07:43 PM
