Lennox G26 Draft Inducer Squeals - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 02:35 PM   #1
lennox g26 draft inducer squeals
Help! I have replaced the draft inducer motor assembly two times since January 2009. It is failing (squealing) again. When it's squealing it doesn't produce enough pressure to set the pressure switch and it will eventually fail entirely. I suspect it may be getting excessive moisture, however the drain system seems to be functioning correctly. This furnace was purchased in 2002 and the first draft inducer started failing just after it was 5 years old. Any ideas why this is happening? Thank you for any help.
mjt57 is offline   Reply With Quote
Old 02-04-2010, 03:01 PM   #2
HVAC Tech/ Browns Fan
When you place that it had a blue and I think white ring? You need to put right one in it what ever the paperwork says
Tator1076 is offline   Reply With Quote
Old 02-04-2010, 03:02 PM   #3
For some reason those have a big promblem with noise with out the rings
Old 02-04-2010, 04:13 PM   #4
What size G26? How big are the vents? How long and how many 90's or 45's?
Tags
draft inducer , g26 , lennox , sqeal
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 08:44 PM
Bang, right before inducer draft motor starts Jan3Sobieski HVAC 1 12-21-2009 04:48 AM
Condensate in draft inducer longhunter1757 HVAC 6 11-08-2009 09:46 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
