-   -   lennox g26 draft inducer squeals (http://www.diychatroom.com/f17/lennox-g26-draft-inducer-squeals-63608/)
mjt57 02-04-2010 02:35 PM
Help! I have replaced the draft inducer motor assembly two times since January 2009. It is failing (squealing) again. When it's squealing it doesn't produce enough pressure to set the pressure switch and it will eventually fail entirely. I suspect it may be getting excessive moisture, however the drain system seems to be functioning correctly. This furnace was purchased in 2002 and the first draft inducer started failing just after it was 5 years old. Any ideas why this is happening? Thank you for any help.
Tator1076 02-04-2010 03:01 PM
When you place that it had a blue and I think white ring? You need to put right one in it what ever the paperwork says
Tator1076 02-04-2010 03:02 PM
For some reason those have a big promblem with noise with out the rings
Marty S. 02-04-2010 04:13 PM
What size G26? How big are the vents? How long and how many 90's or 45's?
