Old 03-01-2012, 10:33 AM   #1
lennox g26 door switch
My lennox furnace was running but the squirrel cage motor was not running. I noticed that the door switch has only 1 wire on it and it is not connected to anything. I thought it wouldn't even try to run with this switch disconnected the schematic shows the switch going to L1 but this terminal is taken. where should this wire be connected?
gardenman is offline   Reply With Quote
Old 03-01-2012, 11:25 AM   #2
how
It sounds like your door switch has already been deactivated as you should have two wires going to that door switch.
And when that door switch is working properly, and the door is off, that furnace should not be working..
how is offline   Reply With Quote
Old 03-01-2012, 12:04 PM   #3
That's what I figured switch generally needs two wires to switch something.
Old 03-01-2012, 12:26 PM   #4
how
The problem with just telling you how the door switch is normally connected and you initiating those changes is us not knowing how incompatable the original electrical furnace bypass may be with that change.
Old 03-01-2012, 08:53 PM   #5
I understand. If I was to do it I would just connect the L1 leg straight to where the switch lead should switch to. I am guessing that is what was done since everything looks quite normal.
Q for Lennox iComfort users or Lennox Pros klingon HVAC 8 02-11-2012 07:29 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 05:01 PM
Lennox G61 quote, also water heater and ac bw77 HVAC 1 06-16-2011 08:12 PM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 03:35 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
