Old 10-09-2012, 12:42 PM   #1
Lennox G26
I have a Lennox G26 with a Johnson Controls pilot control module #G776RGD-11. The furnace blower comes on and there is spark but once the pilot light comes on it almost immediately goes out. I have already replaced the flame sensor but getting the same results. I have read in other forums that the Johnson Controls module is many times the culprit but is there a way for me to test the module before I spend the money on a replacement? Are there any other reasons the furnace would be acting like this?
birky is offline   Reply With Quote
Old 10-09-2012, 12:59 PM   #2
how
Lennox G26
Check that your control module is well grounded so that the rectifyer rod signal can be received.
Clean up the pilot assembly/ burner surface metal immediately around the flame rod while you are at it.
Make sure that the flame rod is enveloped by the pilot flame.
how is offline   Reply With Quote
Undecided between Lennox 13SEER / 11EER 13GCSX or Rheem 14SEER / 12EER RRPL Sommalina HVAC 2 10-05-2012 07:51 PM
Q for Lennox iComfort users or Lennox Pros klingon HVAC 8 02-11-2012 07:29 PM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 05:01 PM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 03:35 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
