Lennox G2303/4-100-6 LIMIT SWITCH - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 07:33 PM   #1
lennox G2303/4-100-6 LIMIT SWITCH
My heater codes say that the primary/secondary limit switch is open. Can anyone tell me what that looks like an how to replace it. Also, what would cause this. If i turn the system off and then turn it back on the heater will work. The heater is maintaining my house at 65 degrees so, i know it still works but, it will not keep it at the setting of the thermostat. My technician is on vacation and i don't want anyone else working on it so, i am turning to the web for your help. Thanks
navnuke is offline   Reply With Quote
Old 01-13-2011, 07:54 PM   #2
HVAC / Plumbing
Chanber getting too hot. Lack of air flow. Not a good idea to run it if it's cycling on limit
kenmac is offline   Reply With Quote
Old 01-13-2011, 08:00 PM   #3
What to doo
Do i need to open more vents or what? My buddy thought that i just needed to change the filter but, it happened again after replacing.
Old 01-13-2011, 08:04 PM   #4
HVAC / Plumbing
Yes, If you have any supply vents closed . Open them. Never close off vents unless your unit was designed to do so. It resricts air flow
Old 01-13-2011, 08:15 PM   #5
Okay
it has been on for about 40 min without shutting off so, i will see how it goes. any more suggestions?
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
Dayton 3E837 Limit Switch Question edanajo HVAC 11 12-04-2009 03:52 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
