-   -   Lennox G20R wont start (http://www.diychatroom.com/f17/lennox-g20r-wont-start-163156/)
lucky66 11-12-2012 10:55 PM
I have a Lennox G20R whisper heat furnace. It is failing to turn on.
I checked the fuse (the fustat fuse and the in-panel fuse). They are both good.
I checked to see if there is 24VAC between R&C - I measure 0V.
There is no clicking or sound when i turn on the unit. The damper door does not even open.
I recently changed the batteries on the controller unit and made sure the unit was working - that was about 3 weeks back (a regular yearly maintenance). The furnace worked after I replaced the batteries.
Any guidance here is appreciated.
Thanks,
-L
how 11-12-2012 11:07 PM
Confirm supply voltage..Does the thermostat have a fan on switch or do you have a meter to confirm supply voltage?
Remove the stat wire in the furnace connected to "R". Put a jumper between R & W to bypass the thermostat circuit.
If you have supply voltage and have jumpered the stat circuit..is the motor that operates the vent door receiving 24V?
lucky66 11-13-2012 12:09 AM
I have a DMM to measure the voltage.
Thermostat has a switch.
I jumpered the stat wires as mentioned. Can you help me on how to check if the motor is receiving 24 VAC? I do not see leads at the motor.
Thanks,
how 11-13-2012 12:23 AM
Did the thermostat fan switch turn on your furnace blower fan?
or
Do you know if the furnace is getting 120V?
I am not sure from your posts if you've measured any power, be it 24V or 120V in the furnace.
ben's plumbing 11-13-2012 06:24 AM
door has to open to 1st before ignition...check for 24 volts to motor on door ...ben sr
lucky66 11-13-2012 09:20 AM
Thanks Ben Sr.
I checked for 24v between R&C terminals. I'm measuring 0. How do I check at the door motor?
Regards,
ben's plumbing 11-13-2012 01:02 PM
Originally Posted by lucky66 (Post 1051161)
Thanks Ben Sr.
Regards,
check your transformer 1 st...120 in on blk & white...24 volt out ...ben sr
lucky66 11-13-2012 11:19 PM
Checked both - I measure 0V at both locations.
I see a black spot behind the control board. I fear that something could have caused this to burn. Any advice on this?
As insurance, I have ordered a new control board.
Appreciate inouts.
Marty S. 11-14-2012 06:21 PM
No voltage means the fuse/breaker is blown. The burned out control board would be why.
yuri 11-14-2012 06:25 PM
AHH the good ole BCC board. Changed many of them and they get pretty roasted on the back when the fan relay blows.:yes:
