Lennox G20 Series Whisper Cracked Heat Exchanger - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 07:00 PM   #1
lennox g20 series whisper cracked heat exchanger
had 10 year old furnace inspected today, minor crack in lower chamber. called lennox to send me replacement part, under warrentee, cannot afford $900 +/- cost to hire someone. they will not send it because I am not one of their "dealers". It's my furnace and warrentee, why won't they send me the part? it is getting real cold here in NE OH.
Bill
wpsimons is offline   Reply With Quote
Old 12-07-2011, 07:06 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Good for Lennox. No one will give a part to anyone unless they are a dealer/distributor. Fom there a contractor puts it in. Safety first.
Sorry about the high cost. Maybe you should shop around different contractors and talk to them about the situation.
Doc Holliday is offline   Reply With Quote
Old 12-07-2011, 07:11 PM   #3
HVAC Tech/ Browns Fan
900 is a lot. We charge 450.00 . Ps by pass damper door. That's what cracked it in the first place
Tator1076 is offline   Reply With Quote
Old 12-07-2011, 07:13 PM   #4
Rewards Points: 582
yes agree with doc safety 1st not saying you can not install but many can't and one mistake could be serious....shop around and get bids..remember its worth it to you and your family... ben
Old 12-07-2011, 07:20 PM   #5
Not only safety but as was the case with Goodman, it wasn't that their equipment was bad but until not too long ago ANYONE could get there hands on pretty much anything and consequently Goodman got a bad rap due to home owners and hacks acting the part of professional hvac technicians and messing systems up within a year or two that could've and should've lasted 10-15.
The Goodman name went downhill quickly. Now they're making a serious comeback but no other equipment manufacturer is going to let that happen to their company.
My two cents.
Old 12-07-2011, 08:08 PM   #6
Bill
i am in NW ohio.....how much will you pay me to travel and change it?
harleyrider is offline   Reply With Quote
Old 12-07-2011, 08:50 PM   #7
Heck for 90% replacement of warranty heat exchanger, paperwork and shipping fees. We charge 650.00 for all.
Old 12-07-2011, 08:50 PM   #8
AKA HVACTECHFW
Rewards Points: 1,208
That is not what cracked it. Plenty of lennox furnaces were made with out the damper and have the same design heat exchanger and they still all cracked in the same place.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-07-2011, 08:52 PM   #9
AKA HVACTECHFW
Bill
Sorry to tell you but that is not a 10yr old furnace. What is the serial number?
IT IS WHAT IT IS
Old 12-07-2011, 09:00 PM   #10
The reason the part goes through a dealer is it's purchased on credit, then shipped,then installed, then warranty paper work filed. They might or might not want the part shipped back for inspection so it has to be stored until the credit comes for the original purchase(which can take several weeks).
You wouldn't want to pay for all that up front then have the claim denied because it wasn't maintained.
Ditto on the call other dealers for a better price. Takes me 2.5 hours to change a heat exchanger in a G20 including drive time. Not drive time to Ohio though!
Old 12-07-2011, 09:10 PM   #11
I'm in Houston, the hvac capitol of the world. My company, 30 years in the biz, charges $200-$400 to clean a slab coil. That takes a very slow and played out 30 minutes, 45 at best. If we have to pull an upflow from its cabinet it can go $600+, two hours.
Heat exchangers run $700-$900 easy.
I think that geographical location plays a big part in pricing. Your biggest commercial company is about as big as our smallest. Our two van commercial companies work the entire US. Our residential companies do as well.
I can put in an 80% furnace for $1800 and have but that's a rarity to go that low.
Old 12-08-2011, 07:22 AM   #12
jkv
WOW guys, lack of coffee this morning
jkv is offline   Reply With Quote
Old 12-08-2011, 03:29 PM   #13
Please accept my apoligies for slandering you and the company that you work for.......I was out of place by my actions I hope you will forgive me.
The Following 2 Users Say Thank You to harleyrider For This Useful Post:
Doc Holliday (12-08-2011), yuri (12-09-2011)
Old 12-08-2011, 10:51 PM   #14
jkv
You have my respect, Thank you for that Harleyrider.
Repair or Replace 13 yr old Furnace with Cracked Heat Exchanger Thor73 HVAC 33 11-12-2011 08:14 PM
Flame Rollout - Bad exchanger or cracked inducer housing gl35 HVAC 4 03-05-2011 12:02 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
