Lennox G20 Series With Aprilaire 600 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 02:18 PM   #1
Lennox G20 Series with Aprilaire 600
We have a Lennox G20Q5/6E-150-1 furnace and an Aprilaire 8363 thermostat that have worked flawlessly for a number of years....UNTIL we added an Aprilaire 600 whole house humidifier.
Now the system cycles in short bursts, seems to "brown out" like a slow loss of power, sometimes the humidifier shuts down.
Would upgrading to the Aprilaire 8570 thermostat solve the issue and is it compatible with the humidifier and furnace?
Your advice is welcome and appreciated.
Thanks!
bives is offline   Reply With Quote
Old 11-27-2011, 02:21 PM   #2
An old Tradesmen
Rewards Points: 6,086
Disconnect the humidifier from the thermostat, and see if it still does it first before getting another thermostat.
Old 11-27-2011, 02:26 PM   #3
Thanks!
how is the humidifier powered?
harleyrider is offline   Reply With Quote
Old 11-27-2011, 04:44 PM   #4
It is hard wired to the furnace
Old 11-27-2011, 05:11 PM   #5
were does it get its 24 volts from, a current sensing relay, or a circut board, or is it piggy backed on the "W" terminal?
Old 11-27-2011, 05:54 PM   #6
Wired into the circuit board
Old 11-27-2011, 08:53 PM   #7
can you post a picture of the humidifier wirering.......its crucial
Tags
aprilaire , g20 , humidifier , lennox , thermostat
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
lennox elite series wesley01 HVAC 1 01-13-2011 05:04 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 03:49 PM
Lennox Elite Series - right fast flashing light. Need Help natemast HVAC 4 10-03-2010 05:55 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
