Lennox G14Q Parts Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2014, 03:48 PM   #1
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Lennox G14Q parts needed
I have an older Pulse furnace in my store that I need to replace the fan controller switch on. Parts houses tell me that part is NLA but will not tell me part number so I can try to find an after market part. This furnace is in excellent condition so I really need to find a replacement part. Finding Lennox part numbers on the web is impossible. I would appreciate it if someone could provide me the OEM part number and possibly an after market solution for it. Lennox model is G14Q4-80-2. Thank you.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-24-2014, 05:06 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
try cozyparts.com
The control may be obsolete as it is a "timed on" type and they are mostly obsolete. There are several other obsolete parts like the gas and air flapper assemblies. I have worked on them since 1980 when they arrived. The heat exchanger should be pressure tested by a Lennox tech for cracks.
Most people are buying new furnaces due to the obsolete part issue.
Old 11-24-2014, 05:15 PM   #3
#1 HAWKEYE FAN
i did try cozy parts also, no luck. I can not believe I would need a new furnace for fan controller switch.
Old 11-24-2014, 05:46 PM   #4
Hvac Pro
yuri's Avatar
That furnace came out in 1980. 34 years ago. No manufacturers stock parts 4 ever. Honeywell made the control and due to very little demand they discontinued it. All about demand and supply. No demand=no supply.
The gas and air flapper assemblies were made by a specialty company and there is no demand so they are not produced or they went out of business.
Less than 5% of the Pulse's I installed are still running. Heat exchangers crack or no parts or too expensive to repair. Every dog has his day.
The Following User Says Thank You to yuri For This Useful Post:
hardwareman (11-25-2014)
Old 11-25-2014, 08:02 AM   #5
#1 HAWKEYE FAN
thanks Yuri, I know the unit is old but it is 93% efficient so I hate to replace it. I was really hoping someone could provide me with an OEM part#, I see used controllers on ebay but don't want to get the wrong one.
Old 11-25-2014, 08:15 AM   #6
Hvac Pro
yuri's Avatar
Unless you live somewhere where you can afford to be w/o heat for a few days what are you going to do when the heat exchanger cracks or another obsolete part fails. You will need a new furnace at some point. Get a basic 1 stage Goodman if you want a good replacement. As a business can you not write some of it off as a expense. Finding old school techs who understand that furnace is difficult as 3/4 of them are retired.
Old 11-25-2014, 06:28 PM   #7
Rewards Points: 242
Heatcraft FTC6-EHO1 Fan timer Lennox 76H31.
I have never seen the timer go bad it is usually the fan relay P-8-10283 66C6701 24V coil DPDT ...
oldbikes is offline   Reply With Quote
Old 11-25-2014, 06:51 PM   #8
Hvac Pro
yuri's Avatar
That is for the G21. The G14 used a L4064 type BUT it had a timer inside to start it "timed on" or the heat exchanger would get red hot and break. Cannot substitute a regular L4064 as it takes too long to heat up.
Old 11-25-2014, 07:15 PM   #9
#1 HAWKEYE FAN
funny thing with mine is it runs constantly, fan motor never shuts off. Blows cool air half the day.
Old 11-26-2014, 04:35 PM   #10
#1 HAWKEYE FAN
scored a used one. Also Honeywell does make a replacement for the original , new # is L4064W1080, costs about $110.00
Trouble shooting Lennox Furnace caveeagle HVAC 5 10-27-2014 09:24 AM
Lennox ML193 with a Filtrete wiz561 HVAC 26 01-15-2012 04:01 PM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 02:35 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
