Hello All...
Well, Last night (9:02pm, Friday, July 11th, 2008) Our house got hit by Lightning.... Now as near as we can figure, as we cant find any actual physical evidence of the Lighntning hit (nor could the Fire Dept.), We think it hit some where near the chimmney.... The fact that the explosion from the lightning sent my wife and I like cats to the ceiling with claws extended was right and I mean right outside the window that we were sitting next too was a pretty good indicator that it was CLOSE...
Course, all electricity went out, the breakers did thier job....
While I was making my rounds to see what and if anything was on fire or damaged when I went into the room in the basement where the furnace and water heater are there was the very clear smell of Ionized Air.
The Fire Dept checked very carefully in that area with the FLIR gun and could find no sign of fire in the walls or the chimmney. They gave the house an "All Clear" and we turned the breakers back on and everything pretty much came back to normal with the exception of the Cable TV Boxs, a DVD Recorder and my Home Theater... Were thinking the Cable system took the biggest hit from it....
Anyway... So today we go to take showers and my wife came out and said, "Um.. I ran out of Hot Water".... Soooo I goes into take a look, Sure enough, The Pilot Lights are out on the Water Heater and on the Furnace.. Baadabing, Badabang... 2 more Victims of the Lightning..
Got the Water Heater to relight, But I cant get the Lennox G11 to relight.
I did the Turn the knob off for 5 Mins, then move to Pilot and push down and hold while putting a match in and lighting the pilot gas, The Pilot lights, but after a min of holding it down, I then release it, the pilot goes out... did the same procedure again, this time holding down for 90 Secs, same result, tried one more time holding down 2 mins, Same thing....
So for those with more knowledge then I.... Whats Next?
Did the Lightning actually take out my Furnace?
Thanks in advance,
Robb
Thankfully in July and not January in Minnesota...
