Lennox G10 Blower Control - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 05:20 PM   #1
I have an older Lennox G10 furnace G10RC2-110-1 and the blower motor stays on for 20 mins after the flame cuts off. I pulled the blower control switch and that appears to be the issue. Its part F41T52 7T04 110C. Can anyone tell me where I can get this part or if there is a replacement?
s6skuzy01 is offline   Reply With Quote
Old 10-12-2008, 07:04 PM   #2
biggles's Avatar
that might be a Klixon thermal disc that closes when it heats up controlling the fan/on to that.check the time the fans stays off when you call for heat right after the burner comes on...do it with a cooled down heatx,run the unit in fan/on for 5 minutes no heat call.the on and off cycle for a fan on a furnace should be somewhat close thru the fan limit disc.
Lennox G12 Blower Motor Problem jimvh2 HVAC 15 03-19-2016 12:27 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Blower control board mlmaher HVAC 1 11-24-2007 02:39 PM
No Blower (Lennox G11Q3E) "Technical" Terry HVAC 3 04-03-2007 08:54 AM
Troubleshoot Blower Motor - Lennox LongShot HVAC 2 12-29-2006 07:30 PM
