Lennox Furnance Motor Buzz But Does Not Start - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 06:21 PM   #1
Lennox furnance motor buzz but does not start
I have a Lennox furnance that is 14 years old.
When pressing the start, in a few seconds, the motor makes buzz sounds and then it shut up. Can motor be repaired to be replaced?
Xinran is offline   Reply With Quote
Old 03-29-2012, 06:37 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
If the motor is bad than it will have to be replaced. It might simply be the start capacitor is bad and not the motor. You need to call a technician but if you have a digital meter that reads microfarads and ohms then you can check the cap and motor yourself.
Thanks.
Doc Holliday is offline   Reply With Quote
Air Compressor blowing start capacitors? BBC3 Electrical 9 04-28-2013 12:34 PM
Lennox AC in upstate NY JasonNY HVAC 9 07-23-2010 03:35 PM
Lennox AC BlueBSH HVAC 1 05-10-2010 04:51 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 07:37 PM
Furnance won't work...question about Lennox G43UF mandirenee HVAC 4 10-09-2009 09:21 PM
