Lennox Furnace In Watchguard Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 05:49 PM   #1
Lennox Furnace in Watchguard mode
My Lennox G40UH-36A-070-03 furnace if giving me trouble recently. Over the past two weeks, it has ended up in Watchguard mode:
A: Burners failed to ignite
B: Limit open more than 3 minutes
C: Lost flame sense 5 times in one heating cycle
D: Pressure switch opened 5 times in one heating cycle
This just circulates the cold air through the house. I have woke up a couple morning with the temp down quite low. I live in MI so this is a big deal with the weather we have had/are having. I have replaced the air filter, taken the flame sensor out and cleaned it with sandpaper and reinstalled it. The igniter gets red so I don't believe thats the problem. At times it runs fine. When it fails to light, I occasionally get flame on one burner(not even always the same burner) and then it goes out within a couple seconds. Most often it doesn't actually get flame. I can smell gas if I check it after it cycles so I don't believe thats the problem. In a possibly related problem with the pilot on my water heater going out. I changed the thermocouple and it still seems to have the same issue. Is it possible for it to be a ventilation issue? The exhaust from each merge together and exit my house from the same vent. I have lived here for about a year and a half. The furnace was installed in 2002. I have tried reading up on other threads to solve the issue prior to posting. I appreciate any and all help I can get to rectify my situation.
Brandon
HardcoreNinja69 is offline   Reply With Quote
Old 02-01-2011, 05:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Probably your gas meter and/or it's regulator are failing and losing pressure intermittently. Seeing that the problem happens with the water heater also it sounds like a supply problem. Call your gas supplier and tell them the symptoms. Hard to diagnose that problem but I have had it happen several times. Check the meter and regulator outside and make sure they are not buried in snow or ice, there is a small screen on the vent of the regulator, make sure it is not blocked.
The Following User Says Thank You to yuri For This Useful Post:
HardcoreNinja69 (02-02-2011)
Old 02-02-2011, 10:09 AM   #3
Thanks for your suggestion yuri. I called the gas company and they came out and checked the line pressure. It was variable so he swapped out the meter and now is constant. Hopefully I won't have more issues.
Old 02-02-2011, 01:40 PM   #4
Hvac Pro
yuri's Avatar
Glad they found it as those intermittent problems can take several visits and complaining to them to get resolved.
Tags
furnace , lennox , watchguard
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
fan does not work in "auto" mode on my Lennox Pulse 21 gas furnace OliverMogan HVAC 1 01-22-2009 08:54 AM
Lennox stuck in Watchguard Mode thate HVAC 12 11-17-2007 04:04 PM
